Emulating MT-32 on an RPi2
General information and assistance with Munt.
Re: Emulating MT-32 on an RPi2
Postby Srandista » 2019-8-09 @ 17:05
I remember, that I receive error during compilation of 2.3.0 a while ago, so I stayed on 2.2.0. Did you have same problem, or all went smoothly?
My overkill "retro" PC - ASRock 4CoreDual-VSTA, Pentium E6500K, 512MB/4GB RAM, Radeon 9500@9700 (Softmod), ESS Solo-1 + Dreamblaster X2, 80GB IDE HDD, Win 98/XP
User avatar
Srandista
Postby gdjacobs » 2019-8-10 @ 02:46
I'm going to build the latest SVN tonight. Feedback to follow.
User avatar
gdjacobs
Postby appiah4 » 2019-8-10 @ 05:21
2.3.0 was butter smooth. I compiles on Debian 10. QtMobility is no longer in repo for that, but I'm not using the GUI just the daemon called from rc.local at boot, so it wasn't an issue.
I haven't tried with the USB MIDI but it should work fine with a simple aconnect between that and mt32d. I will add the “sleep 5” and the aconnect line to rc.local to automate it.
A500:+512K|ACA500+|C1084S
i386:Am386SX-25|4M|TVGA9000B|ES688/OPL
i486:U5S-33|8M|GD5428|ES1868/MUNT-Pi
i586:P133|32M|S3T64+/MX2|V1|CT3980/32M
i686:K6-2/400|64M|V2/SLI|CT4500/32M
S370:P3-1200|384M|GF4Ti4200|MX300
S754:A3700+|2G|X1950PRO|SB0350
User avatar
appiah4
Postby gdjacobs » 2019-8-10 @ 14:50
If you can craft a udev rule that does the aconnect for you, you'll probably be able to dispense with the sleep delay. Similarly, running everything through 14:0 eliminates timing issues with the USB interface or mt32d coming up.
User avatar
gdjacobs
Postby Srandista » 2019-8-10 @ 19:47
appiah4 wrote:QtMobility is no longer in repo for that, but I'm not using the GUI just the daemon called from rc.local at boot, so it wasn't an issue.
This part of the guide wasn't updated on RetroPie, but you can use qtmultimedia5-dev instead as mentioned in OP.
User avatar
Srandista
Postby gdjacobs » 2019-8-13 @ 05:40
I used the Pi 3 base image for Devuan 2.0[1] and compiled with the dependencies listed in the OP. Everything worked swimmingly -- although my wall adapter was acting stupidly, but that's another story.
[1] Download devuan_ascii_2.0.0_arm64_raspi3.img.xz from https://files.devuan.org/devuan_ascii/embedded/
User avatar
gdjacobs
Postby appiah4 » 2019-8-14 @ 09:40
gdjacobs wrote:If you can craft a udev rule that does the aconnect for you, you'll probably be able to dispense with the sleep delay. Similarly, running everything through 14:0 eliminates timing issues with the USB interface or mt32d coming up.
I'm unfortunately not well equipped to do this but I started looking at this: https://linuxconfig.org/tutorial-on-how ... s-in-linux
I guess I need to add a udev role that does the aconnect once mt32d is started and the USB MIDI interface modules are loaded?
Ah, makes sense I guess. It was probably installed by default on Buster.
User avatar
appiah4
Postby gdjacobs » 2019-8-14 @ 13:21
appiah4 wrote:I guess I need to add a udev role that does the aconnect once mt32d is started and the USB MIDI interface modules are loaded?
If you use the MIDI-through device, mt32d doesn't have to be started when you connect the USB MIDI interface.
User avatar
gdjacobs
Postby appiah4 » 2019-8-14 @ 15:28
SMH.. SO I aconnect the USB Midi to Midi Through (14:0?).. And how does that connect to MT32D (128:0) exactly?
User avatar
appiah4
Postby gdjacobs » 2019-8-14 @ 19:03
You connect 14:0 to MT32D. Both links can be established independent of each other, so you don't need to worry about the other side of the equation when adding a device or synth.
User avatar
gdjacobs
Previous
Return to MT-32 General
Who is online
