First post, by Zarhan
After a long pause and upgrade to Windows Vista, I decided to test again the status of emulated MT-32 in Dosbox. Found Gulikoza's build at http://www.si-gamer.net/gulikoza/dosbox.html. Inserted the rom-files to Dosbox's directory and fired up Wing Commander...
Sound effects work perfectly, however, it seems one or more instruments are missing. Most notably this is right at the start ("In distant future, mankind is locked in a deadly war....") where only percussions are present for first few seconds.
Any tips?
