First post, by tokyoracer
- Member
Sorry to be such a pain here. I recently got a real nice example of a Roland MT-32 though I have no idea how to hook it up as it came with no instructions or software. Does it have to have a sound card? I have 2 gameport outputs on my old 386SX machine (one on the mobo and the other on a 3com ISA network card) but only onboard AdLib sound hardware with no possability for other soundcards. I am aware that most run it thru the SB cards but is it possible to actually use the MT-32 on anything other then the SoundBlaster's gameport specifically?
Thanks in advance.
P.s. If it will work will this cable to the trick?:
http://www.ebay.co.uk/itm/1-8m-VGA-15pin-to-M … =item4600d94e61
