First post, by Pingaloka
Hi guys, I have just installed the last version of MUNT, version 1.3.0
I'm trying to run it in Windows XP (service pack 3) but it doesn't seem to work.
My specs:
AMD Athlon XP 2600+ 1.93GHz, 3gb RAM
Diamond MX300 Soundcard, Aureal driver
Windows XP (service pack3)
When I try to open mt32emu-qt.exe I get "This application has failed to start because the application configuration is incorrect..."
Roms are installed and the MT-32 Synth Emulator can be chosen from the Midi music playback menu in Windows.
Also, when trying to open a game using the MT32 I get this error message: "Couldn't open Control ROM file", "Can't open synth"
Any clue of what the problem could be?
Reply 1 of 4, by fantasma
The same thing happened to me when I tried to run it on a clean XP installation, I think I solved it by installing some version of the C++ redistributable.
EDIT: Check here: http://sourceforge.net/projects/munt/files/munt/1.3.0/
Prerequisites: * Microsoft Visual C++ 2008 runtime.
Required for mt32emu_qt and mt32emu_smf2wav Windows binaries. http://www.microsoft.com/en-us/download/detai … s.aspx?id=11895
