First post, by ElectricMonk
I installed the latest MUNT driver, but I've no clue where to cpoy the MT-32/CM-32L ROM patches to. Any thoughts?
Reply 1 of 6, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
There should be some documentation with the drivers...
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 3 of 6, by ElectricMonk
I ended up watching a Youtube Video. Turned out I dumped them at the root of the folder. There wasn't any documentation telling me if it need to go in /bin, /install, or whichever, so I took a chance and just dumped them there. turned out to be the right spot! 😜
Reply 5 of 6, by Dominus
DOSBox Moderator
There is always a root 😉
Anyway depends on what you use on the mac. If you use the QT Mt32 emu then you decide in the GUI where the roms are. If you use anything else you should say so 😉
Reply 6 of 6, by skitters
The Mac is an iMac with Snow Leopard (OS 10.6.😎.
I put the ROM's in /Users/username/roms (which was the default location suggested by MUNT).
I've been testing with MUNT's built-in midi player.
I think the midi files for LucasArts games that I downloaded from Mixnmojo may not be MT32-compatible.
I seem to be having better luck with midi files from Quest Studios that specifically say they are for MT32.
