First post, by Purduecoz
For the SCI1 games, am I getting the best possible sound by choosing the MT-32 with CLI Soundblaster option in the install utility (using munt and dosbox) or do I need to use the general midi and digitized sound effects work arounds that are out there and effectively append the digitized sound effects Into the general midi file?
Thanks!
Reply 1 of 4, by jesolo
SCI1 games' soundtracks were all still composed on the MT-32 (with the exception of maybe one or two titles that were composed on the CM-32L).
Although Sierra did release General MIDI patches for these, they will sound better (in my opinion) on an MT-32.
It was only with the introduction of their SCI1.1 games that they would shift to compose their music for General MIDI (most were composed on the Roland SC-55 Mk1).
Reply 2 of 4, by Purduecoz
Thanks for the information. So, using the configuration I detailed above (Munt with DOSBox), does choosing MT-32 with CLI Soundblaster actually enable the digitized sound effects to be heard as they were originally intended?
Reply 3 of 4, by gdjacobs
I think everything after LB2 was composed for SC55, although the GM for LB2 sounds pretty great anyway.
Reply 4 of 4, by jesolo
Yes, that is correct. For all SCI1 (and later) games, you should have the option in the setup menu to choose Roland MT-32/CM-32L/CM-64/LAPC-I with CMS Sound Blaster.
For a list of which games were written with which version of the interpreter, check out Wikipedia (search for Sierra Creative Interpreter).
