MT-32 motherboard revisions?
First post, by HanJammer
So I own two MT-32 now... both are of the "old" variety... the one I bought recently I wanted to sell with some profit but _of_course_ it can't be that easy, beacause I discovered it has different motherboard than the one I had for few years now...
Old one is SN #871290 it has motherboard is 79377310 01
the one I bought last week is SN #849553 motherboard is 79377310 00
Obvious difference is the main chip.
Also the lower SN one has socketed EPROMs (fw v.1.07, right?) while the higher SN one has them soldered on the PCB (how to check fw version?).
Which one is better?
    987.32 KiB
    1.29 MiB
    804.87 KiB
    1.33 MiB
Reply 1 of 24, by cyclone3d
You can check the ROM version with a key sequence and then powering on. See here:
https://www.philscomputerlab.com/ultimate-rol … 2-tutorial.html
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 2 of 24, by HanJammer
Thanks! I forgot about this guide - I discovered it some time ago, but I never found time to watch the whole of it 😁
Reply 3 of 24, by the Goat
I'm in the same situation as the original poster. I have two MT-32's. Both "old" versions. But different motherboard revisions (79377310 00 vs 79377310 01).
Are there any known differences between the two motherboard revisions? Which one is "better"?
Reply 4 of 24, by BloodyCactus
well if you have 00 + 01 the difference is really obvious if you looked at the pcb. but neither is 'better', they both have quirks. take your pick.
00 is ceramic pga. roms as eeproms
01 is plastic qfp. roms are mask roms.
Reply 5 of 24, by the Goat
BloodyCactus wrote on 2020-05-03, 02:52:
Yes the physical differences are obvious. By 'better' I meant which one produces higher quality audio or has less noise on the line outs? Was the 01 revision made to fix problems with the 00 revision? (ie. rev 01 is better) Or was the 01 revision a cost reduced version? (ie. rev 00 is better)
Reply 6 of 24, by BloodyCactus
no, the 01 was made to reduce the cermiac PGA roland chip to a QFP chip.
Reply 7 of 24, by the Goat
BloodyCactus wrote on 2020-05-03, 12:32:
Roger. In that case I'd say the revision 01 is slightly more desirable (it has mask ROMs for the version 1.07 firmware).
Reply 8 of 24, by BloodyCactus
neither is more desireable than the other. mask roms just means you cant erase and reprogram them. I have an 00, it has 1.07.
Reply 9 of 24, by the Goat
BloodyCactus wrote on 2020-05-03, 18:06:
In this case, mask ROMs are definitely superior to EPROMs. The data stored in EPROMs will be corrupted over time. It takes seconds/minuets when exposed to UV light or decades if the UV light exposure is minimized. But it still happens.
Reply 10 of 24, by darry
the Goat wrote on 2020-05-03, 19:02:
What EEPROMs could I use to replace the EPROMS in mine ? You got me thinking of getting one of those TL866 programmers, dumping the original ROMs and writing them to EEPROMs .
Reply 11 of 24, by the Goat
darry wrote on 2020-05-03, 19:19:
You wouldn't what to use EEPROMs. The MT-32 has no capability or use case to write to the firmware ICs.
The correct EPROMs to use are 27c256.
Reply 12 of 24, by darry
the Goat wrote on 2020-05-03, 19:33:
I know the MT-32 can't write to EEPROMs, I would be using an external programmer (TL866). The reason I want to use EEPROMs instead of EPROMs is that I would rather not have to buy a UV light source to erase them first (can you even still get new blank EPROMs?). However, it seems that using EEPROMs would requiring swaping some pins, so not great either .
Thanks for the model number .
Reply 13 of 24, by the Goat
darry wrote on 2020-05-03, 19:57:
Ahh, I understand.
Reply 14 of 24, by darry
Well, looks like I should have looked inside my MT-32 first : soldered mask ROMs .
So no need to worry about EPROM erasure. FW is 1.07
1.98 MiB
GPL-2.0-or-later
Reply 15 of 24, by HanJammer
But bin files to program your own EPROMs are easly available. OTP ROMs were just cheaper. Also it takes a long time for UV EPROMs with exposed window in direct sunlight to be "erased" (hours if not days) and I'm not sure what kind of UV radiation it should be to erase them in seconds - takes at least couple minutes to erase the UV EPROM in the eraser... so by no means it's worse/better than OTP EPROMs.
PS: Also 29C256 Flash is a direct 27C256 UV EPROM replacement.
PS: Board revision 00 is more rare then 01 as far as I know.
Reply 16 of 24, by the Goat
HanJammer wrote on 2020-05-03, 21:57:
OTP EPROMs are identical to UV erasable EPROMs, just they don't have the window to let in UV light. The data will still be corrupted over time.
The EPROM doesn't need to be erased to turn the MT-32 (or other device) into a brick. Only a single bit needs to flip from a '0' to a '1', or vice versa, to ruin your day.
Reply 18 of 24, by the Goat
darry wrote on 2020-05-03, 22:54:
Any way to tell whether the ROMs are OTP or MASK Roms ?
EDIT: Without decapping them
You can usually guess based on the part number and or company logo on the package. ie. if the chip is branded 'Roland' with a proprietary part number it is probably a Mask ROM. If it is branded AMD or NEC, etc. and has a part number that follows the industry standard for PROMs then you've got a OTP PROM.
Reply 19 of 24, by HanJammer
the Goat wrote on 2020-05-03, 22:52:
OTP EPROMs are identical to UV erasable EPROMs, just they don't have the window to let in UV light. The data will still be corr […]
I have a really good laugh reading your pesimistic comments about EPROMs failing. While it's true EPROMs degrade over time - personally I never seen one failing because of age (even the early 80s BIOS and BASIC EPROMs from 5150s were all working correctly).
ESD or failure because of some other component failed is another thing. And if it fails - so what. Those are just off the shelf parts, easly available and cheap too. Also socketed in case of rev 00 board.
PS: Unlike the ROMs used on 01 board which are Roland branded and soldered on. And good luck finding those masked ROMs in case it fails (not because of it's limited lifespan but for different reason - ie. ESD when you are fiddling inside of the MT-32).
So 00 revision definitely has a big advantage over 01 here.
