First post, by BlackLinus24
Hi,
I recently got hold of an MT-32. I want to connect it to the GamePort of my AWE32 to which a DreamBlaster X2 is already connected. I was wondering if there might be a conflict between the X2 and the MT-32 or are they using different address. To my understanding both could be addressed by using the standard 330 H. So, if for instance I run Monkey Island -r will actually the MT-32 play or might there be a mish-mash of both MT-32 and the X2 playing at the same time.
I wasn't able to try it out yet as I still haven't gathered all the cables necessary to connect the MT-32 to Gameport and Audio-In of the AWE32.
Thanks!
Reply 1 of 3, by appiah4
BlackLinus24 wrote:
Hi, […]
Hi,
Thanks!
The card will send MIDI data to both synthesizers, so you will have to mute the wavetable audio through the software mixer.
Unfortunately, IIRC this means muting Line-In, so you can't route the MT-32 audio back to the AWE32 to internally mix with PCM/OPL3 audio in this case - you would probably have to use an external mixer for the MT-32.
Someone else can probably back that up (or tell me I'm wrong, which is equally likely).
Reply 2 of 3, by BlackLinus24
Thanks. Indeed, muting the line in seems to mute the X2 Wavetable as well. As I wanted to keep my AWE32 with the X2 on the Wavetable port I installed a second ISA sound card into my 486, a Media Vision Jazz16.
Interestingly enough, only the gameport of the AWE32 works. So, the midi signal goes from the gameport of the AWE32 to the MT-32. The audio from the MT-32 goes into the line in of the Jazz16. In order to choose between the different setups (AWE+X2 and Jazz16 + MT-32) I have created different menuitems in the Config.sys and Autoexec.bat (running DOS 6.22).
That works quite well.
Reply 3 of 3, by appiah4
An alternative to using a completely separate second card would probably be making your own back bracket with just a 3.5mm audio jack soldered onto a CD-ROM audio connector, which connects to your AWE32's AUX input header.
Glad you found a setup that works for you though.
