First post, by Whirlinurd
Hi.
Using Dosbox under Retropie for gaming for some time now. I found some tutorials that I could install Munt under Retropie. This was a tutorial originally for Raspberry pi 2 and also one for the Raspberry pi 3 with some build modifications also for a Raspberry pi 3 or 4. I combined the two tutorials tweaking some packages and using Munt 2.4.0 instead of 2.2.0. This worked perfectly now having Roland Midi output under dos.
The only thing is I use the 3.5mm jack for audio. This works fine for all other audio outputs that Retropie uses. When I finished installing Munt audio it is coming out of the HDMI output. The only way I have found until now is by disabling all HDMI audio and forcing all to the audio jack. I have discussed this in the Retropie forum and they think this is not the solution to my problem.
Until now we haven't found anything that works.
This is the tutorial I have used to install Munt:
https://retropie.org.uk/forum/topic/12549/tut … lation-on-rpi-3
After discussing a lot the last thing we tried is changing Step 11 in the tutorial that says '/usr/local/bin/mt32d -i 12&' in '/etc/rc.local' that seems to start Munt with the system to the following:
./mt32d -i 12 -d dmix:CARD=Headphones,DEV=0
I have tried searching around to find anything to fix this but most people use Munt under Windows or with a Retropie setup just leave all audio to HDMI.
I would like to know how it is possible to change the default HDMI output that Munt uses to change this to a Raspberry pi 3.5mm audio output?
Thanks.
Reply 1 of 3, by Whirlinurd
Since several versions of Retropie the audio is not set in raspi-config and it stays on HDMI. Could this be a separate alsa mixer next to the alsa mixer retropie uses. In the Munt tutorial there is also a Munt Alsa Mixer. Everything keeps on mixing everywhere.
This is my aplay -L list:
null
Discard all samples (playback) or generate zero samples (capture)
default
output
sysdefault:CARD=b1
bcm2835 HDMI 1, bcm2835 HDMI 1
Default Audio Device
dmix:CARD=b1,DEV=0
Direct sample mixing device
dsnoop:CARD=b1,DEV=0
Direct sample snooping device
hw:CARD=b1,DEV=0
Direct hardware device without any conversions
plughw:CARD=b1,DEV=0
Hardware device with all software conversions
sysdefault:CARD=Headphones
bcm2835 Headphones, bcm2835 Headphones
dsnoop:CARD=Headphones,DEV=0
hw:CARD=Headphones,DEV=0
plughw:CARD=Headphones,DEV=0
Most of the things are set to Headphones. These are probably the mixer settings of Retropie. Maybe the top ones are from the system mixer raspi-config uses. Or they are just all outputs the mixer has. I do not know. If this is true that the raspi-config mixer sticks to HDMI and it is also the system mixer Munt outputs to it then it keeps using the HDMI audio.
Not sure if I can ever fix this properly. Should I fix something in Retropie... Is it a problem with Munt or is Dosbox doing strange things. I do not know. Does Munt has a config file somewhere or some kind of configuration utility? I am not sure.
The only thing I did until now is this. An alternative for the amixer cset numid thingy that Retropie does not use anymore.
Step 1: Hardware – Default, Headphones, Mixer Alsa
Step 3: sudo nano /boot/cmdline.txt
snd_bcm2835.enable_compat_alsa=1
Step 6: sudo nano /boot/config.txt
hdmi_ignore_edid_audio=1
audio_pwm_mode=2
Step 7a: sudo nano /home/pi/.asoundrc
defaults.pcm.card 1
defaults.ctl.card 1
Step 7b: sudo nano /usr/share/alsa/alsa.conf
defaults.pcm.card 1
defaults.ctl.card 1
This disables all HDMI audio and pushes all audio to the 3.5mm jack.
Is there really no way to properly configure the output of Munt to a specific audio output?
Reply 2 of 3, by Whirlinurd
I feel a bit dumb. Did not know to much about how things work on linux and stuff. It seems that the './mt32d -i 12 -d dmix:CARD=Headphones,DEV=0' is a valid output line but gives no sound output. I was so focused that I was doing something wrong. Finally I tried some other output devices and tried the first one.
/usr/local/bin/mt32d -i 12 -d sysdefault:CARD=Headphones
Just hoping that it would do something else and it worked the first time. If I knew it was this simple.
Thanks. Bye bye.
Reply 3 of 3, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
Thanks for your rant! It will prove useful for someone else! And I love everything munt+pie 😀
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
