Reply 40 of 46, by Great Hierophant
- l33t
I hesitated about mentioning the CM-32LN and LAPC-N because they were made for the NEC 9800, although the latter could be made to work somehow with a PC.
As for the necessary ROMs, Munt requires the control ROMs merged into a single file (if MT-32) but not for the CM-32L (which only has one EPROM.) The "tone" ROM is better known as the PCM ROM and that has always been required. There is another ROM on the MT-32 that contains reverb algorithims, but that is evidently not required at this time.
I believe the Blue Ridge modification allows an MT-32 modified for battery backup to properly retain the RAM contents.
