First post, by SkyHawk
There's a bunch of these having been sold on eBay
https://www.ebay.ca/itm/285243529321?hash=ite … ABk9SR8abkpSLYg
System Board view - https://i.ebayimg.com/images/g/JfcAAOSwI6tkQEbx/s-l1600.jpg
Seller claims to have "upgraded" MT-32s to the CM-32L PCM ROM and control logic.
I was under the impression that was not possible. I'm not interested in buying one of these, but I am very curious how this was done and what the implications are for compatibility of these devices.
I'd guess this is just a CM-32L system board dropped into an MT-32 chassis, but this guy appears to be selling many of these, so probably not? I do spy a headphone jack, so this particular listing at least is not an MT-32(old) board.
Reply 2 of 6, by keropi
Interesting, I thought it was only possible to do in the newer version MT-32 with the headphone jack...
🎵 🎧 PCMIDI MPU , OrpheusII , Action Rewind , Megacard , MK8330 and 🎶GoldLib soundcard website
Reply 3 of 6, by Tiido
This is for 2nd generation MT32s without the PGA LA32 chip, for these you simply use CM32 or LAPC program ROM and burn a new sample ROM with the extra sounds and you get all the fun. You might have to solder a wire to bring in the highest address line to the sample memory chip. 27C801 and one wire should be all that is needed for that.
Reply 4 of 6, by keropi
Turns out the 2nd unit is just a 2nd gen mt32 without the headphone jack. Apparently they exist.
Reply 6 of 6, by keropi
This mod essentially turns a suitable mt32 to a cm32l , I doubt there are compatibility issues different from a real cm32l
it is nice to get the extra sfx and screen if you have a new-version mt32 , can't see any drawbacks to it (except the modification work needed)
