dvorak layout here!
First post, by graig
Just put these in a text file called mapper.txt and put that in the dosbox directory. make sure to make a backup of your old mapper.txt before overwriting it with this dvorak mapping.
hand_shutdown "key 290 mod1"
hand_capmouse "key 291 mod1"
hand_fullscr "key 13 mod2"
hand_pause "key 19"
hand_mapper "key 282 mod1"
hand_scrshot "key 286 mod1"
hand_decfskip "key 288 mod1"
hand_incfskip "key 289 mod1"
hand_cycledown "key 292 mod1"
hand_cycleup "key 293 mod1"
hand_recwave "key 287 mod1"
hand_caprawmidi "key 289 mod1 mod2"
hand_caprawopl "key 288 mod1 mod2"
hand_swapimg "key 285 mod1"
key_esc "key 27"
key_f1 "key 282"
key_f2 "key 283"
key_f3 "key 284"
key_f4 "key 285"
key_f5 "key 286"
key_f6 "key 287"
key_f7 "key 288"
key_f8 "key 289"
key_f9 "key 290"
key_f10 "key 291"
key_f11 "key 292"
key_f12 "key 293"
key_grave "key 96"
key_1 "key 49"
key_2 "key 50"
key_3 "key 51"
key_4 "key 52"
key_5 "key 53"
key_6 "key 54"
key_7 "key 55"
key_8 "key 56"
key_9 "key 57"
key_0 "key 48"
key_minus "key 39"
key_equals "key 93"
key_bspace "key 8"
key_tab "key 9"
key_q "key 120"
key_w "key 44"
key_e "key 100"
key_r "key 111"
key_t "key 107"
key_y "key 116"
key_u "key 102"
key_i "key 103"
key_o "key 115"
key_p "key 114"
key_lbracket "key 45"
key_rbracket "key 61"
key_enter "key 13"
key_capslock "key 301"
key_a "key 97"
key_s "key 59"
key_d "key 104"
key_f "key 121"
key_g "key 117"
key_h "key 106"
key_j "key 99"
key_k "key 118"
key_l "key 112"
key_semicolon "key 122"
key_quote "key 113"
key_backslash "key 92"
key_lshift "key 304"
key_z "key 47"
key_x "key 98"
key_c "key 105"
key_v "key 46"
key_b "key 110"
key_n "key 108" "key 108"
key_m "key 109"
key_comma "key 119"
key_period "key 101"
key_slash "key 91"
key_rshift "key 303"
key_lctrl "key 306"
key_lalt "key 308"
key_space "key 32"
key_ralt
key_rctrl "key 305"
key_printscreen "key 316"
key_scrolllock "key 302"
key_pause "key 19"
key_insert "key 277"
key_home "key 278"
key_pageup "key 280"
key_delete "key 127"
key_end "key 279"
key_pagedown "key 281"
key_up "key 273"
key_left "key 276"
key_down "key 274"
key_right "key 275"
key_numlock "key 300"
key_kp_divide "key 267"
key_kp_multiply "key 268"
key_kp_minus "key 269"
key_kp_7 "key 263"
key_kp_8 "key 264"
key_kp_9 "key 265"
key_kp_plus "key 270"
key_kp_4 "key 260"
key_kp_5 "key 261"
key_kp_6 "key 262"
key_kp_1 "key 257"
key_kp_2 "key 258"
key_kp_3 "key 259"
key_kp_enter "key 271"
key_kp_0 "key 256"
key_kp_period "key 266"
mod_1 "key 305" "key 306"
mod_2 "key 307" "key 308"
mod_3
Reply 1 of 8, by graig
the only problem with this is that there is no way to switch between keyboard layouts on the fly.
it would be nice if this keyboard mapper was an optional program extra. that could be disabled.
i used to be able to use dosbox and type the dos commands in dvorak layout. but when i got into the game i could hit the windows hotkey to change the layout to qwerty for the old games that you could not configure keys for.
Reply 2 of 8, by Guest
This rules, I was hating having to use QWERTY all over again after finally getting use to Dvorak.
IMHO this file should be included with DosBox with an option to switch to dvorak.
Reply 3 of 8, by DrFred
This works very well—thank you.
Thank you,
DrFred
Reply 4 of 8, by ryt
great, i always used xkeyb for dvorak, but this is better
Reply 5 of 8, by DrFred
Would you mind if I asked about the layout of your excellent Dvorak mapper.txt file? I'm curious about the format, and whether it can be edited to change keys.
Thank you,
DrFred
Reply 7 of 8, by Sonjaaa
As of May 2010, the way to do this is to edit the .conf file and change the line that says
keyboardlayout=auto
to
keyboardlayout=dv103
Reply 8 of 8, by robertmo
same way for 3 years now 😉
