First post, by pepoluan
I tried installing DOSbox 0.70 on my laptop and my workstation. I got the Windows "Application Error" stating:
The instruction at "0x6812e699" referenced memory at "0x00000104". The memory could not be "read".
What gives?
    5.39 KiB
    Screencap of Error Dialog Box (6KiB PNG)
I use ISO-8601. You should, too!
Reply 1 of 11, by DosFreak
What operating system?
What video card?
What DX version?
What video card driver version are you using?
Make your games work offline
Reply 2 of 11, by Kreshna Aryaguna Nurzaman
And does it happen on both your laptop and workstation, with exactly the same error?
Kreshna Aryaguna Nurzaman.
Reply 3 of 11, by pepoluan
Workstation is Windows 2003, laptop is Windows XP.
DirectX 9.0c of Feb 2007 is installed.
I use the standard drivers given by Windows.
I'm not sure if the error address and reference is exactly the same. I'll check 'em first.
{p}
Reply 5 of 11, by pepoluan
Gee, I thought I have posted my reply... 😦 ... apparently my ISP had eaten my reply. So, here's an update:
For the Windows 2003, I have installed 865 driver from Intel. Now DOSbox runs without error.
No such luck (drivers) with the laptop...
Reply 8 of 11, by pepoluan
DosFreak wrote:
What kind of video card in the laptop?
Now that's the problem... I have no idea. It's not really my laptop, just one 'entrusted' to me by my office.
Reply 9 of 11, by eL_PuSHeR
Well, you could try running a system identifier software such as Everest or SiSoft Sandra to find out.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 10 of 11, by Peri
I have the same problem, the weird thing is that DOSBox 0.65 works fine. The problem only occurs with DOSBox 0.70. but I tried the 0.70 version in my other Windows instance (clean installation) and it works good. I don't know what is the problem. :<
Reply 11 of 11, by butterfly
That's been suggested already but when I tried DOSBox on Windows 2003 I experienced the same problem. It was enough turning hardware acceleration to the max.
