8086 (amstrad)
First post, by kelp7
I've been trying out Dosbox and it looks very good, but a lot of programs that I wrote in the late 80s and early 90s for my Amstrad PC1512 (a 7mhz 8086 ibm-clone) run too fast on Dosbox. I know that Dosbox emulates various CPUs but is there any way I can get it to 'dumb down' to an 8086 7mhz pc? or does anyone know of either an amstrad pc emulator or 8086 emulator?
thanks
ben
Reply 1 of 6, by Qbix
Rank DOSBox Author
DOSBox Author
play with the cycles variable (ctrl f11 and ctrl f12)
Water flows down the stream
Reply 2 of 6, by kelp7
thanks for the reply, i'll give that a go and see what happens...
Reply 3 of 6, by abyss
For those old games make sure your in normal core and cycles=500 and cyclesup should be 100 and know if the games still run to fast use ctrl f11 and if running too slow ctrl f12. I never knew amstrad made an IBM clone.
Reply 4 of 6, by eL_PuSHeR
In fact, AMSTRAD made several PC clones when IBM was too expensive to buy.
PC1512 - CGA or Monochrome. 512KB. 5¼ floppies.
PC1640 - EGA. 640KB. 5¼ floppies (360KB).
PC2086 - VGA (PVGA1A). 3½ floppies (720KB). I had one of these.
And more models I don't recall. Some with 286 and 386SX.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 5 of 6, by dh4rm4
I had a PC2086 for a short while and my custom made XT clone with NEC V20 was faster, even though the 2086 also had the same 8mhz CPU.
Reply 6 of 6, by kelp7
thanks for all the help. I took the first replier's advice and simply dropped the cycles down to somewhere between 500 to 700.... everything seems to run just fine now, like it used to... 😀
