First post, by x42bn6
Is there a way to export a saved game file and save it onto your hard drive? The way I see the mounting is like a RAM disk, where the game is loaded somewhere in memory and destroyed when DOSBox is closed. But there is a file I want to grab before I close DOSBox, so that I don't have to leave my computer on to continue the game!
Reply 1 of 2, by DosFreak
DosBox mounts your host file system. You are directly accessing your host file system. So if you save a game or delete a file then you saved the game or deleted the file directly onto or off of your hard drive.
Make your games work offline
