First post, by jean
Hi
i use DOSBOX 7.0 with "Nec Note Keyboard with One-Touch start buttons"
i have a problem with some touchs like FS (->), GS (<-), RS, US,
I don't know if i must use mapper to resolv my problem or find a other file keyb?
I am french and my english is poor sorry
thanks for your help
regards
Reply 1 of 19, by wd
Rank DOSBox Author
DOSBox Author
The keyboard layouts are only of use if you have a fully working keyboard
inside dosbox (that is US layout as at this point it is ignored what is printed
onto your real keys). Then you can switch to some layout you're familiar
with (so the output produced by the dosbox shell matches what you read
on your real keys).
Do the letters work (querty in the upper row) and the numbers?
What are those RS/US keys??
Reply 2 of 19, by jean
hi
i don't understand your answer.
i use azerty (fr keyb)
i want to use "up", "lft", "dwn","rgt" touchs . I see them in joystick layout mapper and under Del END PND mapper. So can i configure mapper ? or find (or create) a good keyboard file for my french portable-PC keyboard?
regards
Reply 3 of 19, by wd
Rank DOSBox Author
DOSBox Author
Those are not touches (whatever those are) but belong to the joystick.
Is there any problem with the keyboard, or do you just want to
additionally have some functionality on those up/down touches?
Reply 4 of 19, by jean
hi
in my portable PC keyboard, there are <- and -> keys ( and up and down)
I think to use mapper.
how to know ascii codes link with keyboard key? any programm?
regards
Reply 7 of 19, by jean
Hi
i go on
in my windows98 i have two <- keys (ascii code 75) and (ascii code -32 and ascii 75). My application works fine with theses two keys
now on my XP i have only key (ascii code -32 and ascii 75). My application doesn't work under dosbox but edit.exe works fine under dosbox.
So i don't know where is the problem! 🙁
Any idea?
Another question: with mapper can i put ascii code into key directly in event
(perhaps ascii(75) for example)?
regard
Reply 9 of 19, by jean
hi
i use affascii.exe (tape affascii in google or follow link http://files.codes-sources.com/fichier.aspx?i … &f=affascii.cpp
my keyboard have 87 keys (no Down key in numlock bloc)
regards
Reply 10 of 19, by wd
Rank DOSBox Author
DOSBox Author
The -32 is 0xe0 (implicit conversion to unsigned), that is you're
looking for the extended left key.
In the mapper, there's a block with numbers where its top left
has a NUM. 4 is left, 6 is right (depending on the state of numlock
and the shifts/capslock they act as 4 or left). Thus remap those
numbers to keys that are physically present on your keyboard and
see if it works. If it doesn't switch the state of numlock.
If you don't have numlock try capslock and various combinations
of the two shift keys+capslock on/off.
Reply 11 of 19, by jean
Hi
i don't understand mapper:
now with userscancodes=yes when i tape <- touch, i have 4 and when i tape -> i have 6.!!!
with userscancodes=no when i tape <- touch, i have KK and when i tape -> i have MM.!!!
numlock or shift doesn't change anything?
i am a poor dosbox user 😢
Reply 12 of 19, by wd
Rank DOSBox Author
DOSBox Author
Hm maybe start over, that is delete the mapper.txt and stick to
usescancodes=true for the moment.
After that test what -> and <- produce (type something in the
dosbox window and hit those keys). Please post what happens
(either nothing, or it moves the cursor).
Reply 16 of 19, by wd
Rank DOSBox Author
DOSBox Author
Hm don't know, sounds odd.
Try the following: delete the mapper.txt, start dosbox+the mapper.
Then klick on the "K" and delete all bindings for it (the "DEL" button,
watch the binding, it should be removed).
Then be sure that hitting the "K" key on your keyboard doesn't produce
anything (as the binding was deleted) and see what the <- now does.
Reply 18 of 19, by wd
Rank DOSBox Author
DOSBox Author
Sorry, no idea, maybe somebody else can give you some helpful advice.
Maybe try some older dosbox versions, and try posting a screenshot
after you pressed the up/down/left/right keys on the dosbox prompt.
Reply 19 of 19, by jean
Hi
i don't understand but it works fine!!! 😊
Ctrl A gives <-
Ctrl E up
Ctrl D ->
Ctrl X down
(keyb fr and that's all!!!!)
now i try to print with Dosbox
Thanks lot every body
