DosBox under Vista
First post, by Markito
Hi!
I have read in a few posts that it is possible to run DosBox under Vista, but there are no specific instructions to be found.
I just installed DosBox and when I try to run it, a DOS window appears saying
CONFIG: Loading primary settings from config file C:\Program Files\DOSBox-0.70\dosbox.conf
Then Windows informs me of an error
DosBox has stopped working
How can I fix this. I need a fix of the old Dune 😒
Reply 1 of 6, by MiniMax
Rank Moderator
Moderator
It should just work - no need for special instructions.
Sounds like a problem with your graphics drivers. Try searching the forums here for "SDL_VIDEODRIVER=windib".
_________________
Reply 3 of 6, by ADDiCT
This is a contender for my personal "The strangest and most useless VOGONS posts 2007"-award.
There's no such thing as a "3D part of my videocard". Nowadays, all major functions of modern video adapters are implemented on one IC. Either the card works correctly (=the IC is OK), or it doesn't (=the IC is not OK). There's also some more additional potential for broken components on the card, but i won't go into details here.
If your card is broken, you should have mentioned that in your original post. One person actually wasted time answering to a problem that didn't exist in the form you described it in your original post. If the card is broken, then there's a high probability that you will have multiple problems, both in 3D (gaming) _and_ 2D (OS, applications, etc.). Assuming that DOSBox will run OK on a broken card, just because it's a "2D application" (which it isn't) is just very, very silly. Your answer to MiniMax' post implies that you knew there's something wrong with your hardware before you posted the original question.
Reply 6 of 6, by MiniMax
Rank Moderator
Moderator
*** LOCKED ***
_________________
