Reply 40 of 52, by hsegal
On my new iMac, with .72 now installed, I'm happy to report that I was able to get the dailer working with Telemagic, my contact manager application. This was done with the help of Rolf, who graciously suggested the following lines be put in the file DOSBox Preferences, located under
"/Users/yourusername/Library/Preferences":
[serial]
serial1=directserial realport:cu.usbmodem
I have one remaining issue that I'm trying hard to solve: My application uses the F10 key all the time. And on the iMac, with System Preferences for the Keyboard and Mouse set so that the box is checked for the Function Keys to act as "standard keys", all the keys F1 through F9 work properly, but F10 does not. F10 dims the screen instead. In order to get the F10 key to work as the F10 key, the Command key must be held down at the same time. Anyone have any suggestions for correcting this?
Hal
