actually i think i got it. I hit MD TimeCom then tried CD TimeCom. Now it reads: C:\TimeCom>
But i have a new problem. Inside the folder there are 2 application programs "Install" and "Setup" both do the same thing, they bring me to Time Commando's Menu, where i can hit Play or Install/uninstall. Hitting "play" doesn't do anything.
When i try to activate anything within the TimeCom folder nothing happens. (I am using DOSBox 0.72)
There is a readme that says "AutoRun" with a bunch of commands, but none of them work in DOSBox:
[autorun]
open=setup.exe
icon=timeco.ico
shell\verb0\command=setup.exe INSTALL
shell\verb0=&Install
shell\verb1\command=setup.exe UNINSTALL
shell\verb1=&Uninstall
shell\verb2\command=setup.exe PLAY
shell\verb2=&Play
shell\verb3\command=notepad.exe read.me
shell\verb3=&Read Docs
