First post, by possecomealive
Hi, I want to mount a cdrom with DosBox. To do that I have to type Z:\>MOUNT D D:\ -T cdrom. But here comes the problem. When i try typing ":" and "\" some other symbols comes up. I read in another thread that it is because I don't have an US-Keyboard. So to make DosBox understand my commands, I typed keyb dk (since I'm from Denmark). Well, this made ":" work, but I still can't type "\".
Does anyone know how to solve this problem?
Reply 2 of 12, by Miki Maus
I don't know how much DOSBox keyb command is different from MS-DOS keyb command, but you can also try "keyb dk 850" or "keyb dk 865" and see if that works. (Info on codepages from Non USA Keyboard Layouts)
Reply 3 of 12, by WolverineDK
sorry , that I am going to write in Danish to those who don´t understand Danish.
possecomealive: du kan altså godt trykke på dosbox.conf via din startmenu, og putte keyb dk ind som en start kommando før du begynder at gå ind i dosbox, samt du kan også montere ("mounte") dine drev via den config før du starter dosbox.
Reply 4 of 12, by wd
Rank DOSBox Author
DOSBox Author
Well then write in english, obviously the poster can read it.
Reply 5 of 12, by WolverineDK
Yes, I know he can. But sometimes a very polite apology before hand , when you write in your own language can be understood. And at the same time, I only did it with the apology before that. Heck you can ask him what I wrote, or ask the Dane who lives in Stockholm, what I wrote. Since I didn´t write anything bad.
Reply 6 of 12, by wd
Rank DOSBox Author
DOSBox Author
It might be helpful for other people to know what you wrote.
Guess not all wanna contact that guy just to get that knowledge.
But well.
Reply 7 of 12, by WolverineDK
Well, I wrote he could write the start commands in the dosbox config file. Such as keyb dk and what directory he was going to mount as c:
Reply 8 of 12, by possecomealive
@Wolverine
Tak for svaret. Desværre er jeg ikke så erfaren med programmet, og er ikke helt sikker på hvad der skal rettes. Så måske du kunne fortælle hvor i conf-filen at jeg helt nøjagtig skal gå ind og ændre noget, for at mounte cd'en før jeg åbner dosbox
Reply 9 of 12, by WolverineDK
possecomealive: I hope everybody can read English, since I am going to explain it in English now, and I hope possecomealive will understand it. Or else I will be explaining it in Danish afterwards.
possecomealive: look at your start menu in XP or Vista , there should be a program "folder" that says dosbox, (and some version number afterwards) then you can see an icon called DOSBox.conf and when you click on that, there it pops up in wordpad, and at the bottom you can write after where it says
[autoexec]
# Lines in this section will be run at startup.
and then you can write
keyb dk
And what folder do you have as a "c:" aka. Where do you have your dosgames ? if you have that at multiple places on your harddisk (or do you have multiple drives ?) Anyway, you should have one single folder where all your dosgames are.
And here is an example, let us say it is D:\dosspil. Then you write after keyb dk
mount c d:\dosspil
C:
So your config file after
"[autoexec]
# Lines in this section will be run at startup." should look something like this
Keyb dk
mount c d:\dosspil
C:
if some people wants to correct my writings, then do it. But don´t give me BS. And maybe some people can help him with mounting the cd/dvd drive.
Reply 10 of 12, by eL_PuSHeR
[MOVED]
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 11 of 12, by gidierre
possecomealive wrote :
...so to make DosBox understand my commands, I typed keyb dk (since I'm from Denmark)
if this can help a little bit,
at one time (IIRC Dosbox 0.6x)
I remember using
freedos keyb.exe 2.0 + keyboard.sys
to give you an idea, that would've been from
http://www.ibiblio.org/pub/micro/pc-stuff/fre … ayout/kpdos.htm
and the like
in autoexec this way :
mount c c:\dosboxstuff
mount d d:\ -t cdrom -ioctl
c:
keyb it
HTH
EDIT
I didn't quite understand if you have already tried the simple setting available in
[dos]
# keyboardlayout -- Language code of the keyboard layout (or none).
Reply 12 of 12, by possecomealive
@WolverineDK & gidierre
Thx so much for your answers. I got it working now. Appreciate a lot!
