First post, by DOS_Boy
- Member
Wrote by Dominus on his "Windows 3.x installation guide": - When you mount a floppy drive to a:\ it doesn't show in the Windows file manager and in the "run" dialog you can't select it either. But you can enter the path (for example "a:\setup.exe") and it works ok. When you don't have anything mounted to a:\ the a:\ drive shows up in Windows 3.1x. Strange but true.
It just happened to me in Windows 3.11 FWG, and it's really weird. Is there anything I can do to fix this?
"But listen to me brother, you just keep on walking, 'cause you and me and sister ain't got nothing to hide..." - Scatman John
