First post, by bubs
Is there a way to make graphics better on dosbox like you can on scummvm ?
You will probably get lucky with some CVS build (Gullikoza or someone else). I am not sure.
[MOVED]
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
did you check the configuration file of dosbox ?
# scaler: Scaler used to enlarge/enhance low resolution modes. If 'forced' is appended,the scaler will be used even if the result might not be desired.
# Possible values: none, normal2x, normal3x, advmame2x, advmame3x, advinterp2x, advinterp3x, hq2x, hq3x, 2xsai, super2xsai, supereagle, tv2x, tv3x, rgb2x, rgb3x, scan2x, scan3x
Water flows down the stream
Not sure how to change the configuration. I have gone into dosbox config file but i dont know what to do. Could i change the graphics on willy beamish to super2xsai?
scaler=super2xsai forced
wrote:scaler=super2xsai forced
Does this make the gameplay (and the screenshots taken via Dosbox's Screen Capture feature as well) graphics sharper with a higher resolution?
gameplay yes, screenshots no.
