First post, by justinstrack
I can't seem to record a video of my DOS game. I can record sound and take screenshots, but no video, what is wrong?
I get no error messages.
did you install the codec that comes with 0.72 ?
You don't need the codec to record videos.
Do you get any non-error messages?
Try to remap the record key combination using the mapper, maybe some other
application/tool steals the current one.
wrote:I can't seem to record a video of my DOS game. I can record sound and take screenshots, but no video, what is wrong?
If you're on Windows Vista, and you used the DOSBox regular installer, you can't record videos right off the bat. As far as I know, Vista won't let applications create and alter files under \Program Files\.
Open dosbox.conf and alter the video capture path to something like c:\videos.
He said he can capture images, so write permissions should be fine.
wrote:He said he can capture images, so write permissions should be fine.
He could have changed the image capture path before, no?
Actually he could have changed a number of settings in dosbox.conf that might have spoiled the video capture of course. I suggest you open dosbox.conf and take a look, it usually helps.
Yes and we have a separate directory for those and forcefully switching between those for fun.
