First post, by Dopefish
- Newbie
I've searched the forums, read the DosBox FAQ, but didn't find what i was looking for. I've read somewhere that DosBox doesn't support multi core CPUs, so a single core, very fast (MHz) CPU, is preferable to a quad core, slow (MHz) CPU. Right?
As far as i know, the last single core CPU was Pentium 4. Would a 3-3.6 GHz CPU be enough for running the most demanding dos games on DosBox? Or is it overkill and should choose a lower CPU, like a 2GHz one?
Has DosBox a limit when it comes to how much cpu power uses?
And one more thing, unrelated to CPU, but to software. I know there isn't any DosBox x64 version, but will it help in theory?
Thank you for your time.
