Emulate PC Speaker with Soundcard
First post, by bur
It seems like if you have no PC speaker it can be emulated with the soundcard, is that true?
Thing is, I have a PC speaker and still rather have it emulated with the soundcard. Reason being it sounds a little awkward for today's ears 😅 and also there is a very audible *click* if no sound is played for 3-4 seconds and the speaker shuts down (or whatever it's called).
Reply 1 of 44, by Qbix
Rank DOSBox Author
DOSBox Author
dosbox emulates the pc speaker on the soundcard.
and it can turn itself off if it isn't used. Though I fixed the click, but maybe I didn't commit that code yet.
Water flows down the stream
Reply 2 of 44, by bur
And how do I activate this? When setting pcspeaker=true in the config it played the sound through the real pc speaker.
edit: Haha, sorry. It really played through the soundblaster I just didn't notice. 😕 Now that's a good emulation...
Maybe that "click" is fixed in the patched builds? I have the official 0.72 version.
Reply 3 of 44, by Qbix
Rank DOSBox Author
DOSBox Author
Haha! that is a big compliment 😀
Reply 4 of 44, by bur
I just got the newest CVS build and that clicking sound is still there. So if you have a fix for this ready, it'd be nice if you could add it to the CVS.
Reply 5 of 44, by Qbix
Rank DOSBox Author
DOSBox Author
btw do you have a special game in which it is very audable ? It's been ages since I tested the fix
Reply 6 of 44, by bur
I'm currently playing Secret Agent from Apogee and since the speaker is only used when jumping or shooting the sound often gets turned off with that clicking sound.
I checked and it also happens withCrystal Caves from Apogee. Both games use the same engine I think so maybe that's why.
Reply 7 of 44, by MiniMax
Rank Moderator
Moderator
And here is the legal place to download those games:
http://www.3drealms.com/downloads.html
_________________
Reply 8 of 44, by bur
It's only been the shareware at the above links. 😀
Reply 9 of 44, by jal
As long as those versions also experience the click, no problem there I guess 😀.
JAL
Reply 10 of 44, by bur
What I meant was the links I posted also only lead to the shareware. So there was no need to remove them. No problem though as that sound problem appears in all episodes (incl shareware) like you said.
I just wanted to emphasize on the fact I hadn't broken a rule... 😉
Reply 11 of 44, by MiniMax
Rank Moderator
Moderator
I know it is nitpicking, but there is a difference between a license holder making the software available for free from their own site, and someone else distributing copies of the same software from another site. Unless that someone has obtained the distribution rights, it is not legal...
So read my words again:
_________________
Reply 12 of 44, by jal
I think you get on murky legal grounds there, but I agree it's safer to link from the official page. In general though, it depends on the redistribution rights the author/publisher grants (usually in the copyright file).
JAL
Reply 13 of 44, by Kippesoep
The VENDOR.DOC file included with the games explicitly states:
Everyone can -- and is encouraged! -- to copy, upload and generally pass around this Program without charging for it.
That means it's perfectly legal to host or download copies of the first (shareware) episode anywhere, provided it's unaltered (as mentioned in that same file). The other episodes are not shareware and there it doesn't apply, of course.
Reply 14 of 44, by Tsyu
It's audible in pretty much every game that uses the PC speaker. If you need a specific game to test this, I would suggest King's Quest I (AGI) or II. The click occurs about one second after every tune and sound effect. This happens in both 0.72 and CVS.
I have posted in image that shows what the output looks like. Take note of the highlighted section, as it shows the cause of the click.
I hope this gets fixed in 0.73.
Reply 15 of 44, by Qbix
Rank DOSBox Author
DOSBox Author
yes, that is the exact turning off of the speaker. the jump at the back is the click you hear.
Reply 16 of 44, by MikeSol
In Wizardry 7, when you choose internal speaker as your sound effects source you will hear a popping noise after each effect is played. I am assuming this is the clicking noise discussed here. I just started a thread about this problem recently over in the games section.
Reply 17 of 44, by Tsyu
Right. I was really referring to the section between the sound and the "pop." As you can probably tell, it is the part during which the speaker is silent, but still activated. I don't think a real PC speaker makes that popping sound. I would think the samples of this section should be centered like the ones after the deactivation. This would get rid of that annoying click. I've posted an edit of my previous image to show you what I mean.
Reply 18 of 44, by Qbix
Rank DOSBox Author
DOSBox Author
well our pc speaker emulation keeps it's last value active. (so that the low part). Then it detects that it hasn't changed in a "long" time and turns itself off. (which results in a jump to zero).
The correct image would be even a bit different.
It would be a slowly converging line towards zero. so when it turn off there is no click.
Reply 19 of 44, by Tsyu
That would work if the converging line doesn't end up making a "humming" artifact. SpeakerCorrect2.png shows what I believe you're talking about.
Another way to fix the popping would be to do what the Tandy 3-voice emulation seems to do--place the zero point in the center of the waveform. This would eliminate the click, as well as the need for a converging line. SpeakerCorrect3.png shows what this would look like.
Edit:
So you're sort of saying that the speaker emulation code places the silence at either the top or bottom of the waveform, depending on when the silence occurs? I'm asking this because I have never seen the silence happen at the top of the waveform. Is it even possible to perform any of my suggestions without a complete overhaul of the code?
Edit again: Just saw wd's post. I'll let this rest.
