First post, by tomanoj
when we copy a file from one folder to another folder it does not ask a option whether to "OverWrite Yes/No", the problem is that suppose u keep program files in a folder called PROG, while working u copy that program file into a folder called WORK, but after completing when u copy the files back into original program folder using copy command it does not ask for any confirmation, so in that case u are not sure whether file was copied of the correct folder or even u type by mistake a diff folder name , u won;t get to know anything unless u check the folders,
is there any option to enable this or whether it can be included in next version of dosbox
Reply 1 of 5, by Qbix
Rank DOSBox Author
DOSBox Author
games don't need the "overwrite yes/no" question. Hence it isn't present in DOSBox
Water flows down the stream
Reply 2 of 5, by tomanoj
its not related to games, but when u are in doxbox and try and copy files using copy command from one folder to another folder, there this confirmation will help, which is present into normal dos
Reply 3 of 5, by wd
Rank DOSBox Author
DOSBox Author
Use your host OS's copy capabilities.
Reply 4 of 5, by MiniMax
Rank Moderator
Moderator
... or run real MS-DOS inside DOSBox.
_________________
Reply 5 of 5, by ADDiCT
...or use 4DOS.
