First post, by Ruediger
When using parameters at batch files at DOSBox, the second "%" character is not correctly replaced by the interpreter.
Example:
If I create a batch file TEST.BAT containing only this line:
echo %1%
and start it from the DOSBox with
TEST one
I get the output "one%".
Running the same batch file at DOS or Windows, the (correct) output is "one".
Reply 1 of 5, by wd
Rank DOSBox Author
DOSBox Author
dosbox version?
Reply 2 of 5, by MiniMax
Rank Moderator
Moderator
Hmmm. I have never used 2 %'s when dealing with positional parameters. Why not just use %1 ?
_________________
Reply 3 of 5, by HunterZ
I thought %foo% was for environment variables (like %PATH%) and %1 was for parameters (not %1%).
Reply 4 of 5, by Ruediger
My DOSBox Version is 0.73
Reply 5 of 5, by wd
Rank DOSBox Author
DOSBox Author
