Start menu
Reply 20 of 33, by Qbix
Rank DOSBox Author
DOSBox Author
No 3d menu lovers here ?
I tended to just type the commands directly in DOS though. Only had a 105 mb harddrive, so not that many games installed; (old time dosbox users might recall the that size from somewhere 😉 )
Water flows down the stream
Reply 21 of 33, by rfnagel
@leileilol,
"Quiver" in yer pic 😀 Hehe, I used to describe that oldie as "poor man's Quake" <grin> 😀
Sadist boar wrote:
Found PAS confusing. 😲
Seriously Guy, any new program that someone hasn't used before; they'll have to sit down and actually learn how/figure out how to use it 😉
Anyhow, like I said before, QM3 😀
I used to spend a lot of time in DOS and Norton Commander, both shelled out from QuikMenu III.
Hehe, QM3 has the option of keeping a log of everything that you do within it (running programs and such), and I found it interesting every once in a while to check my logs and see what I'd been running/using the most.
Hehe, a DOS shell, Norton Commander, and Windows 3.11 (running Cakewalk Pro v3,01) was always at the top of the list, with hundreds of hours for each <grin> 😀
Rich ¥Weeds¥ Nagel
http://www.richnagel.net
Reply 22 of 33, by Jorpho
They're nifty-looking and all, but don't menu programs generally inhibit game compatibility? I would think that if one wanted to avoid having to type things in DOSBox, an external frontend would be the way to go.
Reply 23 of 33, by Sadist boar
Well, I'd like a tool that would let me generate a batch with sub-menus - like pressing genre name's first letter, then game name's
Quest
Kyrandia II: Hand of Fate
Sad fat people are never good at using complex programs.
Reply 24 of 33, by Jorpho
Then I suggest using the code that rfnagel posted on the previous page. If you want submenus, then make additional .bat files and chain them together. (DOSBox supports Call, right?)
The only simpler thing I can think of is to set up an MS-DOS "boot" image that will let you use the config.sys-based MS-DOS menu system, but that brings in other limitations DOSBox-wise.
Reply 25 of 33, by Sadist boar
Modding even that code can be troublesome, especially with multiple batches. I am a winhead, who always needs a "setup wizard". #_#
Reply 27 of 33, by Jorpho
Even if such a generator existed, it really couldn't be much less "troublesome" than modding that code yourself.
If you're such a "winhead", why do you want some menu that runs within DOSBox, anyway? If you're after some kind of authentic-DOS flavor, then few would disagree that modifying your own code is an integral part of the experience.
Reply 28 of 33, by rfnagel
Eggsactly. That's what I don't understand... he wants an easy-to-use menu system akin to the easy-ness of a batch file (minus the batch file coding/editing), but doesn't like the Windows sort-of-look-alike QM3? 😕
Nothing could be easier to set up and use than QM3; and it too, supports single keypress hotkeys (re: my pics of my "Weeds" QM3 setup, the "Letter = AppName" labels on the icons and buttons).
I mean, setting up "shortcuts" in QM3 (and to some degree, Point and Shoot as well) isn't hardly any more difficult or troublesome than right-clicking on your WinDoZe desktop and "New/Shortcut/fill_in_the_info_or_browse_for_EXE" 😀
Anyhow, the DOSBox.conf that I normally use will/can run about 99% of the games and old DOS apps that I use or have. Hence, QM3 would work great for it... one DOSBox.conf that runs damned near everything, and a nice menu to run it from within DOSBox 😀
@SB,
Don't take this the wrong way, but your current forum signature line "Sad fat people are never good at using complex programs" <grin> 😉
Rich ¥Weeds¥ Nagel
Reply 29 of 33, by rfnagel
Hehe, now HERE is a batch file for ya 🤣!
(Part 1 of 2)
@ECHO OFF
C&CWEEDS /FAD /KEY /W4
:TOP
CLS
@ECHO Command and Conquer: Tiberian Dawn - [T]he ¥Weeds¥ Edition
@ECHO ----------------------------------------------------------
@ECHO Command and Conquer [G]DI Missions
@ECHO Command and Conquer [N]OD Missions
@ECHO Command and Conquer Covert [O]perations Missions
@ECHO Command and Conquer [J]urassic Park Missions
@ECHO.
@ECHO Command and Conquer Manual, Maps, Strategy Guides, and [W]alkthroughs »
@ECHO Command and Conquer Official [F]AQ
@ECHO Command and Conquer [K]eyboard Controls
@ECHO Command and Conquer [H]idden Options Enabler Utility
@ECHO C&Cheat Utility Manual and [R]eadme
@ECHO C&Cheat Utility Keyboard [C]ontrols
@ECHO.
@ECHO Command and Conquer [M]edia, Movies, and Music »
@ECHO.
@ECHO [B]ackup and Restore Command and Conquer Files »
@ECHO Command and Conquer [S]ound Configuration
@ECHO [E]dit Command and Conquer "CONQUER.INI" Configuration File
@ECHO.
@ECHO [A]ssault Trooper - BONUS GAME »
@ECHO.
@ECHO Norton Commander [5].0 / [D]OS Prompt
@ECHO [Q]uit
CHOOSE /CTGNOJWFKHRCMBSEA5DQ
IF ERRORLEVEL 19 GOTO QUIT
IF ERRORLEVEL 18 GOTO DOSPROMPT
IF ERRORLEVEL 17 GOTO NCTOP
IF ERRORLEVEL 16 GOTO ASSAULT
IF ERRORLEVEL 15 GOTO EDIT
IF ERRORLEVEL 14 GOTO SOUND
IF ERRORLEVEL 13 GOTO BACKUPRESTORE
IF ERRORLEVEL 12 GOTO MEDIA
IF ERRORLEVEL 11 GOTO CONTROLS
IF ERRORLEVEL 10 GOTO README
IF ERRORLEVEL 9 GOTO HIDDEN
IF ERRORLEVEL 8 GOTO KEYBOARD
IF ERRORLEVEL 7 GOTO FAQ
IF ERRORLEVEL 6 GOTO WALKTHROUGHS
IF ERRORLEVEL 5 GOTO JURASSIC
IF ERRORLEVEL 4 GOTO OPERATIONS
IF ERRORLEVEL 3 GOTO NOD
IF ERRORLEVEL 2 GOTO GDI
IF ERRORLEVEL 1 GOTO WEEDS
:WEEDS
GOTO TOP
:GDI
C&C -CDCDROMS\GDI\ %1 %2 %3 %4 %5 %6 %7 %8 %9
GOTO TOP
:NOD
C&C -CDCDROMS\NOD\ %1 %2 %3 %4 %5 %6 %7 %8 %9
…Show last 1705 lines
GOTO TOP
:OPERATIONS
C&C -CDCDROMS\COVERT\ %1 %2 %3 %4 %5 %6 %7 %8 %9
GOTO TOP
:JURASSIC
C&C -CDCDROMS\COVERT\ FUNPARK %1 %2 %3 %4 %5 %6 %7 %8 %9
GOTO TOP
:WALKTHROUGHS
CLS
@ECHO Command and Conquer Manual, Maps, Strategy Guides, and Walkthroughs
@ECHO -------------------------------------------------------------------
@ECHO Command and Conquer [P]DF Manual
@ECHO.
@ECHO Command and Conquer [S]trategy and Tactics Guide
@ECHO Command and Conquer [U]nofficial Strategy FAQ and Missions Walkthrough
@ECHO.
@ECHO Command and Conquer Missions [W]alkthrough
@ECHO Command and Conquer [D]euce ex Defcon Covert Operations Missions Walkthrough
@ECHO Command and Conquer Covert [O]perations and Jurassic Park Missions Walkthrough
@ECHO Command and Conquer Nintendo 64 and Playstation Special Ops Mission [B]riefings
@ECHO.
@ECHO Command and Conquer [G]DI Missions Maps »
@ECHO Command and Conquer [N]OD Missions Maps »
@ECHO Command and Conquer Covert Operations Missions [M]aps »
@ECHO Command and Conquer [J]urassic Park Missions Maps »
@ECHO.
@ECHO.
@ECHO « Return to [C]ommand and Conquer Main Menu
@ECHO.
@ECHO [Q]uit
CHOOSE /CPSUWDOBGNMJ5CQ
IF ERRORLEVEL 14 GOTO QUIT
IF ERRORLEVEL 13 GOTO TOP
IF ERRORLEVEL 12 GOTO NCWALKTHROUGHS
IF ERRORLEVEL 11 GOTO JPMAPS
IF ERRORLEVEL 10 GOTO COVERTMAPS
IF ERRORLEVEL 9 GOTO NODMAPS
IF ERRORLEVEL 8 GOTO GDIMAPS
IF ERRORLEVEL 7 GOTO BRIEFINGS
IF ERRORLEVEL 6 GOTO COVERTWALKTHROUGH
IF ERRORLEVEL 5 GOTO DEUCEWALKTHROUGH
IF ERRORLEVEL 4 GOTO MISSIONSWALKTHROUGH
IF ERRORLEVEL 3 GOTO UNOFFICIALFAQ
IF ERRORLEVEL 2 GOTO STRATEGYGUIDE
IF ERRORLEVEL 1 GOTO PDFMANUAL
:PDFMANUAL
CLS
@ECHO Note: Open the file "C&C\DOCS\MANUAL\MAIN.PDF" using the Adobe Acrobat Reader
@ECHO for Windows to view the Command and Conquer PDF manual.
@ECHO.
@ECHO Press any key to return to the Command and Conquer Manual, Maps, Strategy
@ECHO Guides, and Walkthroughs menu...
PAUSE>NUL
REM @ECHO Press ALT+TAB after viewing the Command and Conquer PDF manual to return to the
REM @ECHO Command and Conquer Manual, Maps, Strategy Guides, and Walkthroughs menu.
REM @ECHO.
REM @ECHO Press any key to continue...
REM PAUSE>NUL
REM RUNDLL32 URL.DLL,FileProtocolHandler DOCS\MANUAL\MAIN.PDF
GOTO WALKTHROUGHS
:STRATEGYGUIDE
EDIT DOCS\STRATEGY\C&CGUIDE.TXT
GOTO WALKTHROUGHS
:UNOFFICIALFAQ
EDIT DOCS\STRATEGY\CCSFAQ70.TXT
GOTO WALKTHROUGHS
:MISSIONSWALKTHROUGH
EDIT DOCS\STRATEGY\C&CWALK.TXT
GOTO WALKTHROUGHS
:DEUCEWALKTHROUGH
EDIT DOCS\STRATEGY\COOPWALK.TXT
GOTO WALKTHROUGHS
:COVERTWALKTHROUGH
EDIT DOCS\STRATEGY\COVTWALK.TXT
GOTO WALKTHROUGHS
:BRIEFINGS
EDIT SCONSOLE.TXT
GOTO WALKTHROUGHS
:GDIMAPS
CLS
@ECHO Command and Conquer GDI Missions Maps
@ECHO [A] - SCG01EA Mission 1, Estonia [N] - SCG08EB Mission 8, Slovakia
@ECHO [B] - SCG02EA Mission 2, Estonia [O] - SCG09EA Mission 9, Hungary
@ECHO [C] - SCG03EA Mission 3, Latvia [P] - SCG10EA Mission 10, Slovenia
@ECHO [D] - SCG04EA Mission 4, Belarus [Q] - SCG10EB Mission 10, Romania
@ECHO [E] - SCG04WA Mission 4, Belarus [R] - SCG11EA Mission 11, Greece
@ECHO [F] - SCG04WB Mission 4, Poland [S] - SCG12EA Mission 12, Albania
@ECHO [G] - SCG05EA Mission 5, Ukraine [T] - SCG12EB Mission 12, Bulgaria
@ECHO [H] - SCG05EB Mission 5, Ukraine [U] - SCG13EA Mission 13, Yugoslavia
@ECHO [I] - SCG05WA Mission 5, Germany [V] - SCG13EB Mission 13, Yugoslavia
@ECHO [J] - SCG05WB Mission 5, Germany [W] - SCG14EA Mission 14, Yugoslavia
@ECHO [K] - SCG06EA Mission 6, Czech Republic [X] - SCG15EA Mission 15, Bosnia
@ECHO [L] - SCG07EA Mission 7, Czech Republic [Y] - SCG15EB Mission 15, Bosnia
@ECHO [M] - SCG08EA Mission 8, Austria [Z] - SCG15EC Mission 15, Bosnia
@ECHO.
@ECHO [5] - European Theatre GDI Missions Map
@ECHO.
@ECHO [6] - Norton Commander 5.0
@ECHO.
@ECHO « [7] - Return to Manual, Maps, Strategy Guides, and Walkthroughs Menu
@ECHO « [8] - Return to Command and Conquer Main Menu
@ECHO.
@ECHO [9] - Quit
CHOOSE /CABCDEFGHIJKLMNOPQRSTUVWXYZ56789
IF ERRORLEVEL 31 GOTO QUIT
IF ERRORLEVEL 30 GOTO TOP
IF ERRORLEVEL 29 GOTO WALKTHROUGHS
IF ERRORLEVEL 28 GOTO NCGDIMAPS
IF ERRORLEVEL 27 GOTO EUROPE
IF ERRORLEVEL 26 GOTO SCG15EC
IF ERRORLEVEL 25 GOTO SCG15EB
IF ERRORLEVEL 24 GOTO SCG15EA
IF ERRORLEVEL 23 GOTO SCG14EA
IF ERRORLEVEL 22 GOTO SCG13EB
IF ERRORLEVEL 21 GOTO SCG13EA
IF ERRORLEVEL 20 GOTO SCG12EB
IF ERRORLEVEL 19 GOTO SCG12EA
IF ERRORLEVEL 18 GOTO SCG11EA
IF ERRORLEVEL 17 GOTO SCG10EB
IF ERRORLEVEL 16 GOTO SCG10EA
IF ERRORLEVEL 15 GOTO SCG09EA
IF ERRORLEVEL 14 GOTO SCG08EB
IF ERRORLEVEL 13 GOTO SCG08EA
IF ERRORLEVEL 12 GOTO SCG07EA
IF ERRORLEVEL 11 GOTO SCG06EA
IF ERRORLEVEL 10 GOTO SCG05WB
IF ERRORLEVEL 9 GOTO SCG05WA
IF ERRORLEVEL 8 GOTO SCG05EB
IF ERRORLEVEL 7 GOTO SCG05EA
IF ERRORLEVEL 6 GOTO SCG04WB
IF ERRORLEVEL 5 GOTO SCG04WA
IF ERRORLEVEL 4 GOTO SCG04EA
IF ERRORLEVEL 3 GOTO SCG03EA
IF ERRORLEVEL 2 GOTO SCG02EA
IF ERRORLEVEL 1 GOTO SCG01EA
:SCG01EA
DOCS\MAPS\GDI\SCG01EA
GOTO GDIMAPS
:SCG02EA
DOCS\MAPS\GDI\SCG02EA
GOTO GDIMAPS
:SCG03EA
DOCS\MAPS\GDI\SCG03EA
GOTO GDIMAPS
:SCG04EA
DOCS\MAPS\GDI\SCG04EA
GOTO GDIMAPS
:SCG04WA
DOCS\MAPS\GDI\SCG04WA
GOTO GDIMAPS
:SCG04WB
DOCS\MAPS\GDI\SCG04WB
GOTO GDIMAPS
:SCG05EA
DOCS\MAPS\GDI\SCG05EA
GOTO GDIMAPS
:SCG05EB
DOCS\MAPS\GDI\SCG05EB
GOTO GDIMAPS
:SCG05WA
DOCS\MAPS\GDI\SCG05WA
GOTO GDIMAPS
:SCG05WB
DOCS\MAPS\GDI\SCG05WB
GOTO GDIMAPS
:SCG06EA
DOCS\MAPS\GDI\SCG06EA
GOTO GDIMAPS
:SCG07EA
DOCS\MAPS\GDI\SCG07EA
GOTO GDIMAPS
:SCG08EA
DOCS\MAPS\GDI\SCG08EA
GOTO GDIMAPS
:SCG08EB
DOCS\MAPS\GDI\SCG08EB
GOTO GDIMAPS
:SCG09EA
DOCS\MAPS\GDI\SCG09EA
GOTO GDIMAPS
:SCG10EA
DOCS\MAPS\GDI\SCG10EA
GOTO GDIMAPS
:SCG10EB
DOCS\MAPS\GDI\SCG10EB
GOTO GDIMAPS
:SCG11EA
DOCS\MAPS\GDI\SCG11EA
GOTO GDIMAPS
:SCG12EA
DOCS\MAPS\GDI\SCG12EA
GOTO GDIMAPS
:SCG12EB
DOCS\MAPS\GDI\SCG12EB
GOTO GDIMAPS
:SCG13EA
DOCS\MAPS\GDI\SCG13EA
GOTO GDIMAPS
:SCG13EB
DOCS\MAPS\GDI\SCG13EB
GOTO GDIMAPS
:SCG14EA
DOCS\MAPS\GDI\SCG14EA
GOTO GDIMAPS
:SCG15EA
DOCS\MAPS\GDI\SCG15EA
GOTO GDIMAPS
:SCG15EB
DOCS\MAPS\GDI\SCG15EB
GOTO GDIMAPS
:SCG15EC
DOCS\MAPS\GDI\SCG15EC
GOTO GDIMAPS
:EUROPE
DOCS\MAPS\GDI\EUROPE
GOTO GDIMAPS
:NCGDIMAPS
CLS
C:\NC\NC
C:
CD\
CD\C&C
GOTO GDIMAPS
:NODMAPS
CLS
@ECHO Command and Conquer NOD Missions Maps
@ECHO [A] - SCB01EA Mission 1, Libya [N] - SCB07EC Mission 7, African Republic
@ECHO [B] - SCB02EA Mission 2, Egypt [O] - SCB08EA Mission 8, Zaire
@ECHO [C] - SCB02EB Mission 2, Egypt [P] - SCB08EB Mission 8, Zaire
@ECHO [D] - SCB03EA Mission 3, Sudan [Q] - SCB09EA Mission 9, Egypt
@ECHO [E] - SCB03EB Mission 3, Sudan [R] - SCB10EA Mission 10, Angola
@ECHO [F] - SCB04EA Mission 4, Chad [S] - SCB10EB Mission 10, Tanzania
@ECHO [G] - SCB04EB Mission 4, Chad [T] - SCB11EA Mission 11, Namibia
@ECHO [H] - SCB05EA Mission 5, Mauritania [U] - SCB11EB Mission 11, Mozambique
@ECHO [I] - SCB06EA Mission 6, Ivory Coast [V] - SCB12EA Mission 12, Botswana
@ECHO [J] - SCB06EB Mission 6, Benin [W] - SCB13EA Mission 13, South Africa
@ECHO [K] - SCB06EC Mission 6, Nigeria [X] - SCB13EB Mission 13, South Africa
@ECHO [L] - SCB07EA Mission 7, Gabon [Y] - SCB13EC Mission 13, South Africa
@ECHO [M] - SCB07EB Mission 7, Cameroon
@ECHO.
@ECHO [5] - African Theatre NOD Missions Map
@ECHO.
@ECHO.
@ECHO.
@ECHO [9] - Quit
CHOOSE /CABCDEFGHIJKLMNOPQRSTUVWXY56789
IF ERRORLEVEL 30 GOTO QUIT
IF ERRORLEVEL 29 GOTO TOP
IF ERRORLEVEL 28 GOTO WALKTHROUGHS
IF ERRORLEVEL 27 GOTO NCNODMAPS
IF ERRORLEVEL 26 GOTO AFRICA
IF ERRORLEVEL 25 GOTO SCB13EC
IF ERRORLEVEL 24 GOTO SCB13EB
IF ERRORLEVEL 23 GOTO SCB13EA
IF ERRORLEVEL 22 GOTO SCB12EA
IF ERRORLEVEL 21 GOTO SCB11EB
IF ERRORLEVEL 20 GOTO SCB11EA
IF ERRORLEVEL 19 GOTO SCB10EB
IF ERRORLEVEL 18 GOTO SCB10EA
IF ERRORLEVEL 17 GOTO SCB09EA
IF ERRORLEVEL 16 GOTO SCB08EB
IF ERRORLEVEL 15 GOTO SCB08EA
IF ERRORLEVEL 14 GOTO SCB07EC
IF ERRORLEVEL 13 GOTO SCB07EB
IF ERRORLEVEL 12 GOTO SCB07EA
IF ERRORLEVEL 11 GOTO SCB06EC
IF ERRORLEVEL 10 GOTO SCB06EB
IF ERRORLEVEL 9 GOTO SCB06EA
IF ERRORLEVEL 8 GOTO SCB05EA
IF ERRORLEVEL 7 GOTO SCB04EB
IF ERRORLEVEL 6 GOTO SCB04EA
IF ERRORLEVEL 5 GOTO SCB03EB
IF ERRORLEVEL 4 GOTO SCB03EA
IF ERRORLEVEL 3 GOTO SCB02EB
IF ERRORLEVEL 2 GOTO SCB02EA
IF ERRORLEVEL 1 GOTO SCB01EA
:SCB01EA
DOCS\MAPS\NOD\SCB01EA
GOTO NODMAPS
:SCB02EA
DOCS\MAPS\NOD\SCB02EA
GOTO NODMAPS
:SCB02EB
DOCS\MAPS\NOD\SCB02EB
GOTO NODMAPS
:SCB03EA
DOCS\MAPS\NOD\SCB03EA
GOTO NODMAPS
:SCB03EB
DOCS\MAPS\NOD\SCB03EB
GOTO NODMAPS
:SCB04EA
DOCS\MAPS\NOD\SCB04EA
GOTO NODMAPS
:SCB04EB
DOCS\MAPS\NOD\SCB04EB
GOTO NODMAPS
:SCB05EA
DOCS\MAPS\NOD\SCB05EA
GOTO NODMAPS
:SCB06EA
DOCS\MAPS\NOD\SCB06EA
GOTO NODMAPS
:SCB06EB
DOCS\MAPS\NOD\SCB06EB
GOTO NODMAPS
:SCB06EC
DOCS\MAPS\NOD\SCB06EC
GOTO NODMAPS
:SCB07EA
DOCS\MAPS\NOD\SCB07EA
GOTO NODMAPS
:SCB07EB
DOCS\MAPS\NOD\SCB07EB
GOTO NODMAPS
:SCB07EC
DOCS\MAPS\NOD\SCB07EC
GOTO NODMAPS
:SCB08EA
DOCS\MAPS\NOD\SCB08EA
GOTO NODMAPS
:SCB08EB
DOCS\MAPS\NOD\SCB08EB
GOTO NODMAPS
:SCB09EA
DOCS\MAPS\NOD\SCB09EA
GOTO NODMAPS
:SCB10EA
DOCS\MAPS\NOD\SCB10EA
GOTO NODMAPS
:SCB10EB
DOCS\MAPS\NOD\SCB10EB
GOTO NODMAPS
:SCB11EA
DOCS\MAPS\NOD\SCB11EA
GOTO NODMAPS
:SCB11EB
DOCS\MAPS\NOD\SCB11EB
GOTO NODMAPS
:SCB12EA
DOCS\MAPS\NOD\SCB12EA
GOTO NODMAPS
:SCB13EA
DOCS\MAPS\NOD\SCB13EA
GOTO NODMAPS
:SCB13EB
DOCS\MAPS\NOD\SCB13EB
GOTO NODMAPS
:SCB13EC
DOCS\MAPS\NOD\SCB13EC
GOTO NODMAPS
:AFRICA
DOCS\MAPS\NOD\AFRICA
GOTO NODMAPS
:NCNODMAPS
CLS
C:\NC\NC
C:
CD\
CD\C&C
GOTO NODMAPS
:COVERTMAPS
CLS
@ECHO Command and Conquer Covert Operations Missions Maps
@ECHO [A] - SCG22EA GDI Mission, Blackout
@ECHO [B] - SCG23EA GDI Mission, Hell's Fury
@ECHO [C] - SCG36EA GDI Mission, Infiltrated!
@ECHO [D] - SCG38EA GDI Mission, Elemental Imperative
@ECHO [E] - SCG40EA GDI Mission, Ground Zero
@ECHO [F] - SCG41EA GDI Mission, Twist of Fate
@ECHO [G] - SCG50EA GDI Mission, Blindsided
@ECHO [H] - SCB20EA NOD Mission, Bad Neighborhood
@ECHO [I] - SCB21EA NOD Mission, Deceit
@ECHO [J] - SCB30EA NOD Mission, Eviction Notice
@ECHO [K] - SCB31EA NOD Mission, The Tiberium Strain
@ECHO [L] - SCB32EA NOD Mission, Cloak and Dagger
@ECHO [M] - SCB33EA NOD Mission, Hostile Takeover
@ECHO [N] - SCB35EA NOD Mission, Under Siege: C&C
@ECHO [O] - SCB37EA NOD Mission, NOD Death Squad
@ECHO.
@ECHO.
@ECHO.
@ECHO [9] - Quit
CHOOSE /CABCDEFGHIJKLMNO6789
IF ERRORLEVEL 18 GOTO TOP
IF ERRORLEVEL 17 GOTO WALKTHROUGHS
IF ERRORLEVEL 16 GOTO NCCOVERTMAPS
IF ERRORLEVEL 15 GOTO SCB37EA
IF ERRORLEVEL 14 GOTO SCB35EA
IF ERRORLEVEL 13 GOTO SCB33EA
IF ERRORLEVEL 12 GOTO SCB32EA
IF ERRORLEVEL 11 GOTO SCB31EA
IF ERRORLEVEL 10 GOTO SCB30EA
IF ERRORLEVEL 9 GOTO SCB21EA
IF ERRORLEVEL 8 GOTO SCB20EA
IF ERRORLEVEL 7 GOTO SCG50EA
IF ERRORLEVEL 6 GOTO SCG41EA
IF ERRORLEVEL 5 GOTO SCG40EA
IF ERRORLEVEL 4 GOTO SCG38EA
IF ERRORLEVEL 3 GOTO SCG36EA
IF ERRORLEVEL 2 GOTO SCG23EA
IF ERRORLEVEL 1 GOTO SCG22EA
:SCG22EA
DOCS\MAPS\COVERT\SCG22EA
GOTO COVERTMAPS
:SCG23EA
DOCS\MAPS\COVERT\SCG23EA
GOTO COVERTMAPS
:SCG36EA
DOCS\MAPS\COVERT\SCG36EA
GOTO COVERTMAPS
:SCG38EA
DOCS\MAPS\COVERT\SCG38EA
GOTO COVERTMAPS
:SCG40EA
DOCS\MAPS\COVERT\SCG40EA
GOTO COVERTMAPS
:SCG41EA
DOCS\MAPS\COVERT\SCG41EA
GOTO COVERTMAPS
:SCG50EA
DOCS\MAPS\COVERT\SCG50EA
GOTO COVERTMAPS
:SCB20EA
DOCS\MAPS\COVERT\SCB20EA
GOTO COVERTMAPS
:SCB21EA
DOCS\MAPS\COVERT\SCB21EA
GOTO COVERTMAPS
:SCB30EA
DOCS\MAPS\COVERT\SCB30EA
GOTO COVERTMAPS
:SCB31EA
DOCS\MAPS\COVERT\SCB31EA
GOTO COVERTMAPS
:SCB32EA
DOCS\MAPS\COVERT\SCB32EA
GOTO COVERTMAPS
:SCB33EA
DOCS\MAPS\COVERT\SCB33EA
GOTO COVERTMAPS
:SCB35EA
DOCS\MAPS\COVERT\SCB35EA
GOTO COVERTMAPS
:SCB37EA
DOCS\MAPS\COVERT\SCB37EA
GOTO COVERTMAPS
:NCCOVERTMAPS
CLS
C:\NC\NC
C:
CD\
CD\C&C
GOTO COVERTMAPS
:JPMAPS
CLS
@ECHO Command and Conquer Jurassic Park Missions Maps
@ECHO [A] - SCJ01EA Mission 1, NOD vs Dinosaurs
@ECHO [B] - SCJ02EA Mission 2, NOD vs Dinosaurs (Command and Conquer Version)
@ECHO [C] - SCJ02EA Mission 2, NOD vs Dinosaurs (Covert Operations Version)
@ECHO [D] - SCJ03EA Mission 3, NOD vs Dinosaurs
@ECHO [E] - SCJ04EA Mission 4, NOD vs Dinosaurs
@ECHO [F] - SCJ05EA Mission 5, Dinosaurs vs NOD (Command and Conquer Version)
@ECHO [G] - SCJ05EA Mission 5, Dinosaurs vs NOD (Covert Operations Version)
@ECHO.
@ECHO.
@ECHO.
@ECHO [9] - Quit
CHOOSE /CABCDEFG6789
IF ERRORLEVEL 11 GOTO QUIT
IF ERRORLEVEL 10 GOTO TOP
IF ERRORLEVEL 9 GOTO WALKTHROUGHS
IF ERRORLEVEL 8 GOTO NCJPMAPS
IF ERRORLEVEL 7 GOTO SCJ05EAO
IF ERRORLEVEL 6 GOTO SCJ05EAC
IF ERRORLEVEL 5 GOTO SCJ04EA
IF ERRORLEVEL 4 GOTO SCJ03EA
IF ERRORLEVEL 3 GOTO SCJ02EAO
IF ERRORLEVEL 2 GOTO SCJ02EAC
IF ERRORLEVEL 1 GOTO SCJ01EA
:SCJ01EA
DOCS\MAPS\JURASSIC\SCJ01EA
GOTO JPMAPS
:SCJ02EAC
DOCS\MAPS\JURASSIC\SCJ02EAC
GOTO JPMAPS
:SCJ02EAO
DOCS\MAPS\JURASSIC\SCJ02EAO
GOTO JPMAPS
:SCJ03EA
DOCS\MAPS\JURASSIC\SCJ03EA
GOTO JPMAPS
:SCJ04EA
DOCS\MAPS\JURASSIC\SCJ04EA
GOTO JPMAPS
:SCJ05EAC
DOCS\MAPS\JURASSIC\SCJ05EAC
GOTO JPMAPS
:SCJ05EAO
DOCS\MAPS\JURASSIC\SCJ05EAO
GOTO JPMAPS
:NCJPMAPS
CLS
C:\NC\NC
C:
CD\
CD\C&C
GOTO JPMAPS
:NCWALKTHROUGHS
CLS
C:\NC\NC
C:
CD\
CD\C&C
GOTO WALKTHROUGHS
:FAQ
EDIT DOCS\C&C\CCFAQ30.TXT
GOTO TOP
:KEYBOARD
EDIT DOCS\C&C\C&C.KEY
GOTO TOP
:HIDDEN
CLS
@ECHO Select "Restore All Hidden Options to [D]efault (Disabled) Status" from within
@ECHO the Command and Conquer Hidden Options Enabler Utility to restore all of
@ECHO Command and Conquer's hidden options back to their default (disabled) status.
@ECHO.
@ECHO Note that you can also restore all of the hidden options by selecting "Restore
@ECHO Command and Conquer Game [E]xecutable" or "Restore [A]ll Command and Conquer
@ECHO Options, High Scores, Saved Games, and EXE" from within the Command and Conquer
@ECHO ¥Weeds¥ Edition launcher menu as well.
@ECHO.
REM @ECHO Also note that after running the Command and Conquer Hidden Options Enabler
REM @ECHO Utility "dummy" DOS network drivers will be loaded to support the "DISABLE
REM @ECHO Human Players Check for [L]AN Multiplayer Games" option within the utility.
REM @ECHO.
PAUSE>NUL
C&C_HOE
@ECHO.
REM @ECHO Press any key to load the "dummy" DOS network drivers...
REM PAUSE>NUL
REM CLS
REM [Packet_Int_No] [Int_Level] [IO_Addr]
REM ^^^^ ^ ^^^^^
REM NE2000 0X60 4 0X310
REM IPX
REM @ECHO.
@ECHO Press any key to return to the Command and Conquer Main Menu...
PAUSE>NUL
GOTO TOP
:README
EDIT DOCS\C&CHEAT\C&CHEAT.TXT
GOTO TOP
:CONTROLS
EDIT DOCS\C&CHEAT\C&CHEAT.KEY
GOTO TOP
:MEDIA
CLS
@ECHO Command and Conquer Media, Movies, and Music
@ECHO Command and Conquer European [T]heatre Movie
@ECHO.
@ECHO Command and Conquer [G]DI Movies
@ECHO Command and Conquer [N]OD Movies
@ECHO Command and Conquer Covert [O]perations Movies
@ECHO.
@ECHO Movie Player [K]eyboard Controls and Manual
@ECHO Movie Player [S]ound Configuration
@ECHO.
@ECHO Command and Conquer GDI [B]ase Wallpaper
@ECHO.
@ECHO Command and Conquer [M]usic
@ECHO.
@ECHO.
@ECHO.
@ECHO [Q]uit
CHOOSE /CTGNOKSBM5CQ
IF ERRORLEVEL 9 GOTO NCMEDIA
IF ERRORLEVEL 8 GOTO MUSIC
IF ERRORLEVEL 7 GOTO BASE
IF ERRORLEVEL 6 GOTO VQAPLAYSOUND
IF ERRORLEVEL 5 GOTO VQAPLAYKEYBOARD
IF ERRORLEVEL 4 GOTO VQAPLAYOPERATIONS
IF ERRORLEVEL 3 GOTO VQAPLAYNOD
IF ERRORLEVEL 2 GOTO VQAPLAYGDI
IF ERRORLEVEL 1 GOTO THEATRE
:THEATRE
MEDIA\MOVIES\THEATRE
GOTO MEDIA
:VQAPLAYGDI
CLS
@ECHO After each movie plays, immediately press "N" to quickly advance to the Next
@ECHO movie in the playlist, or immediately press "R" to Return to the Command and
@ECHO Conquer Media, Movies, and Music menu.
@ECHO.
@ECHO Note that the next movie in the playlist will automatically start playing after
@ECHO one second, and that the movie playlist is looped.
@ECHO.
PAUSE>NUL
@ECHO.
GOTO VQALOOPGDI
:VQALOOPGDI
@ECHO Play [N]ext movie, or [R]eturn to Command and Conquer Media, Movies, and Music
@ECHO menu. Now Playing movie: BANNER
CHOOSE /CNR/T:N,1
IF ERRORLEVEL 2 GOTO MEDIA
VQAPLAY CDROMS\GDI\MOVIES.MIX 0x19370A6C
@ECHO menu. Now Playing movie: BCANYON
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\GDI\MOVIES.MIX 0x18E81E2C
@ECHO menu. Now Playing movie: BKGROUND
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\GDI\MOVIES.MIX 0x17FF2940
@ECHO menu. Now Playing movie: BOMBAWAY
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\GDI\MOVIES.MIX 0x17AA05FC
@ECHO menu. Now Playing movie: BOMBFLEE
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\GDI\MOVIES.MIX 0x177E632E
@ECHO menu. Now Playing movie: BURDET1
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\GDI\MOVIES.MIX 0x16DF88B8
@ECHO menu. Now Playing movie: BURDET2
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\GDI\MOVIES.MIX 0x16C0114A
@ECHO menu. Now Playing movie: CC2TEASE
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\GDI\MOVIES.MIX 0x160B241A
@ECHO menu. Now Playing movie: CONSYARD
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\GDI\MOVIES.MIX 0x159322CE
@ECHO menu. Now Playing movie: DESOLAT
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\GDI\MOVIES.MIX 0x1513306C
@ECHO menu. Now Playing movie: DINO
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\GDI\MOVIES.MIX 0x14FE9F34
@ECHO menu. Now Playing movie: FLAG
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\GDI\MOVIES.MIX 0x14BCE06C
@ECHO menu. Now Playing movie: FLYY
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\GDI\MOVIES.MIX 0x14A7EB10
@ECHO menu. Now Playing movie: FORESTKL
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\GDI\MOVIES.MIX 0x149103D6
@ECHO menu. Now Playing movie: GAMEOVER
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\GDI\MOVIES.MIX 0x14712A3C
@ECHO menu. Now Playing movie: GDI1
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\GDI\MOVIES.MIX 0x13FA3C76
@ECHO menu. Now Playing movie: GDI2
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\GDI\MOVIES.MIX 0x112BE034
@ECHO menu. Now Playing movie: GDI3
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\GDI\MOVIES.MIX 0x10D8CF2C
@ECHO menu. Now Playing movie: GDI3LOSE
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\GDI\MOVIES.MIX 0x10B63C82
@ECHO menu. Now Playing movie: GDI4A
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\GDI\MOVIES.MIX 0x1072536C
@ECHO menu. Now Playing movie: GDI4B
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\GDI\MOVIES.MIX 0x100D9062
@ECHO menu. Now Playing movie: GDI5
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\GDI\MOVIES.MIX 0x0FD34D5E
@ECHO menu. Now Playing movie: GDI6
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\GDI\MOVIES.MIX 0x0F96E1FC
@ECHO menu. Now Playing movie: GDI7
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\GDI\MOVIES.MIX 0x0F5627DC
@ECHO menu. Now Playing movie: GDI8A
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\GDI\MOVIES.MIX 0x0F0EDBB8
@ECHO menu. Now Playing movie: GDI8B
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\GDI\MOVIES.MIX 0x0EBD9D3E
@ECHO menu. Now Playing movie: GDI9
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\GDI\MOVIES.MIX 0x0E09742C
@ECHO menu. Now Playing movie: GDI10
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\GDI\MOVIES.MIX 0x13A2528C
@ECHO menu. Now Playing movie: GDI11
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\GDI\MOVIES.MIX 0x13485C42
@ECHO menu. Now Playing movie: GDI12
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\GDI\MOVIES.MIX 0x13105EA6
@ECHO menu. Now Playing movie: GDI13
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\GDI\MOVIES.MIX 0x12A711F4
@ECHO menu. Now Playing movie: GDI14
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\GDI\MOVIES.MIX 0x12567622
@ECHO menu. Now Playing movie: GDI15
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\GDI\MOVIES.MIX 0x11A42B20
@ECHO menu. Now Playing movie: GDIEND1
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\GDI\MOVIES.MIX 0x0C873A98
@ECHO menu. Now Playing movie: GDIEND2
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\GDI\MOVIES.MIX 0x0B060D56
@ECHO menu. Now Playing movie: GDIFINA
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\GDI\MOVIES.MIX 0x0A41630C
@ECHO menu. Now Playing movie: GDIFINB
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\GDI\MOVIES.MIX 0x09323D12
@ECHO menu. Now Playing movie: GDILOSE
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\GDI\MOVIES.MIX 0x09123A1A
@ECHO menu. Now Playing movie: GENERIC
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\GDI\MOVIES.MIX 0x145AFF28
@ECHO menu. Now Playing movie: GUNBOAT
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\GDI\MOVIES.MIX 0x08E157A0
@ECHO menu. Now Playing movie: HELLVALY
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\GDI\MOVIES.MIX 0x087BBC1A
@ECHO menu. Now Playing movie: INTRO2
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\GDI\MOVIES.MIX 0x073A676E
@ECHO menu. Now Playing movie: LANDING
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\GDI\MOVIES.MIX 0x0721BAA8
@ECHO menu. Now Playing movie: LOGO
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\GDI\MOVIES.MIX 0x06EB5E22
@ECHO menu. Now Playing movie: NAPALM
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\GDI\MOVIES.MIX 0x06AE44F0
@ECHO menu. Now Playing movie: NITEJUMP
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\GDI\MOVIES.MIX 0x0675C4BA
@ECHO menu. Now Playing movie: NOD1
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\GDI\MOVIES.MIX 0x062E9CE0
@ECHO menu. Now Playing movie: NODFLEES
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\GDI\MOVIES.MIX 0x05FFF9B6
@ECHO menu. Now Playing movie: NODLOSE
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\GDI\MOVIES.MIX 0x05B168BA
@ECHO menu. Now Playing movie: NODSWEEP
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\GDI\MOVIES.MIX 0x0579D57C
@ECHO menu. Now Playing movie: PARATROP
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\GDI\MOVIES.MIX 0x05494E8C
@ECHO menu. Now Playing movie: PINTLE
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\GDI\MOVIES.MIX 0x051F3AEC
@ECHO menu. Now Playing movie: PLANECRA
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\GDI\MOVIES.MIX 0x04D1A1FA
@ECHO menu. Now Playing movie: PODIUM
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\GDI\MOVIES.MIX 0x04A70CF2
@ECHO menu. Now Playing movie: RETRO
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\GDI\MOVIES.MIX 0x0444DEA4
@ECHO menu. Now Playing movie: SABOTAGE
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\GDI\MOVIES.MIX 0x042FB7CA
@ECHO menu. Now Playing movie: SAMDIE
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\GDI\MOVIES.MIX 0x03F69ED4
@ECHO menu. Now Playing movie: SAMSITE
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\GDI\MOVIES.MIX 0x03E11962
@ECHO menu. Now Playing movie: SEIGE
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\GDI\MOVIES.MIX 0x03B7CF28
@ECHO menu. Now Playing movie: TBRINFO1
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\GDI\MOVIES.MIX 0x02518C1C
@ECHO menu. Now Playing movie: TBRINFO2
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\GDI\MOVIES.MIX 0x015A6D42
@ECHO menu. Now Playing movie: TBRINFO3
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\GDI\MOVIES.MIX 0x0075F8B4
@ECHO menu. Now Playing movie: TURTKILL
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\GDI\MOVIES.MIX 0x00434280
@ECHO menu. Now Playing movie: VISOR
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\GDI\MOVIES.MIX 0x00000306
GOTO VQALOOPGDI
:VQAPLAYNOD
CLS
@ECHO.
@ECHO.
PAUSE>NUL
@ECHO.
GOTO VQALOOPNOD
:VQALOOPNOD
@ECHO menu. Now Playing movie: AIRSTRK
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\NOD\MOVIES.MIX 0x1818CA26
@ECHO menu. Now Playing movie: AKIRA
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\NOD\MOVIES.MIX 0x17A1B7F2
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\NOD\MOVIES.MIX 0x177FB352
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\NOD\MOVIES.MIX 0x1730C712
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\NOD\MOVIES.MIX 0x16DBA3CE
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\NOD\MOVIES.MIX 0x16B00100
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\NOD\MOVIES.MIX 0x15FB13D0
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\NOD\MOVIES.MIX 0x15831284
@ECHO menu. Now Playing movie: DESFLEES
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\NOD\MOVIES.MIX 0x1559E5CA
@ECHO menu. Now Playing movie: DESKILL
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\NOD\MOVIES.MIX 0x15434258
@ECHO menu. Now Playing movie: DESSWEEP
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\NOD\MOVIES.MIX 0x150CE1DA
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\NOD\MOVIES.MIX 0x14F850A2
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\NOD\MOVIES.MIX 0x14B691DA
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\NOD\MOVIES.MIX 0x149FAAA0
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\NOD\MOVIES.MIX 0x147FD106
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\NOD\MOVIES.MIX 0x141F0E54
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\NOD\MOVIES.MIX 0x1408E340
@ECHO menu. Now Playing movie: INSITES
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\NOD\MOVIES.MIX 0x1401DC7E
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\NOD\MOVIES.MIX 0x12C087D2
@ECHO menu. Now Playing movie: KANEPRE
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\NOD\MOVIES.MIX 0x11B9C36A
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\NOD\MOVIES.MIX 0x11A116A4
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\NOD\MOVIES.MIX 0x116ABA1E
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\NOD\MOVIES.MIX 0x11239244
@ECHO menu. Now Playing movie: NOD1PRE
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\NOD\MOVIES.MIX 0x0F793CA6
@ECHO menu. Now Playing movie: NOD2
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\NOD\MOVIES.MIX 0x0F0B5CD6
@ECHO menu. Now Playing movie: NOD3
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\NOD\MOVIES.MIX 0x0ED46164
@ECHO menu. Now Playing movie: NOD4A
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\NOD\MOVIES.MIX 0x0E99CD98
@ECHO menu. Now Playing movie: NOD4B
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\NOD\MOVIES.MIX 0x0E5EC9B6
@ECHO menu. Now Playing movie: NOD5
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\NOD\MOVIES.MIX 0x0DF97192
@ECHO menu. Now Playing movie: NOD6
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\NOD\MOVIES.MIX 0x0DAD0812
@ECHO menu. Now Playing movie: NOD7A
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\NOD\MOVIES.MIX 0x0D64B29C
@ECHO menu. Now Playing movie: NOD7B
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\NOD\MOVIES.MIX 0x0D1D6AF2
@ECHO menu. Now Playing movie: NOD8
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\NOD\MOVIES.MIX 0x0C6C727E
@ECHO menu. Now Playing movie: NOD9
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\NOD\MOVIES.MIX 0x0BDDA7E2
@ECHO menu. Now Playing movie: NOD10A
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\NOD\MOVIES.MIX 0x10B59F44
@ECHO menu. Now Playing movie: NOD10B
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\NOD\MOVIES.MIX 0x10542C38
@ECHO menu. Now Playing movie: NOD11
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\NOD\MOVIES.MIX 0x100D8922
@ECHO menu. Now Playing movie: NOD12
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\NOD\MOVIES.MIX 0x0FA92F70
@ECHO menu. Now Playing movie: NOD13
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\NOD\MOVIES.MIX 0x0F7F466E
@ECHO menu. Now Playing movie: NODEND1
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\NOD\MOVIES.MIX 0x0A3F0A32
@ECHO menu. Now Playing movie: NODEND2
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\NOD\MOVIES.MIX 0x089FC952
@ECHO menu. Now Playing movie: NODEND3
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\NOD\MOVIES.MIX 0x07173DD2
@ECHO menu. Now Playing movie: NODEND4
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\NOD\MOVIES.MIX 0x05919AD2
@ECHO menu. Now Playing movie: NODFINAL
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\NOD\MOVIES.MIX 0x042DAB58
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\NOD\MOVIES.MIX 0x03DF1A5C
@ECHO menu. Now Playing movie: NUKE
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\NOD\MOVIES.MIX 0x03AF64D6
@ECHO menu. Now Playing movie: OBEL
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\NOD\MOVIES.MIX 0x0374A06C
@ECHO menu. Now Playing movie: REFINT
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\NOD\MOVIES.MIX 0x0326F574
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\NOD\MOVIES.MIX 0x02C4C726
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\NOD\MOVIES.MIX 0x02AF41B4
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\NOD\MOVIES.MIX 0x0285F77A
@ECHO menu. Now Playing movie: SETHPRE
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\NOD\MOVIES.MIX 0x01DF6C48
@ECHO menu. Now Playing movie: SPYCRASH
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\NOD\MOVIES.MIX 0x01C2A3F8
@ECHO menu. Now Playing movie: STEALTH
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\NOD\MOVIES.MIX 0x017DA474
@ECHO menu. Now Playing movie: SUNDIAL
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\NOD\MOVIES.MIX 0x0145E470
@ECHO menu. Now Playing movie: TANKGO
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\NOD\MOVIES.MIX 0x0130788C
@ECHO menu. Now Playing movie: TANKKILL
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\NOD\MOVIES.MIX 0x00FE21EA
@ECHO menu. Now Playing movie: TIBERFX
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\NOD\MOVIES.MIX 0x0078D86C
@ECHO menu. Now Playing movie: TRTKIL_D
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\NOD\MOVIES.MIX 0x00434250
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\NOD\MOVIES.MIX 0x000002D6
GOTO VQALOOPNOD
:VQAPLAYOPERATIONS
CLS
@ECHO.
@ECHO.
PAUSE>NUL
@ECHO.
GOTO VQALOOPOPERATIONS
:VQALOOPOPERATIONS
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\COVERT\MOVIES.MIX 0x0BE62958
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\COVERT\MOVIES.MIX 0x0B6F1724
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\COVERT\MOVIES.MIX 0x0B4D1284
@ECHO menu. Now Playing movie: BANR_NOD
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\COVERT\MOVIES.MIX 0x0B2B1854
@ECHO menu. Now Playing movie: BLACKOUT
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\COVERT\MOVIES.MIX 0x0AE67358
@ECHO menu. Now Playing movie: BODYBAGS
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\COVERT\MOVIES.MIX 0x0AD4053E
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\COVERT\MOVIES.MIX 0x0A7EE1FA
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\COVERT\MOVIES.MIX 0x0A533F2C
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\COVERT\MOVIES.MIX 0x099468D4
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\COVERT\MOVIES.MIX 0x091C6788
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\COVERT\MOVIES.MIX 0x08F33ACE
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\COVERT\MOVIES.MIX 0x0873486C
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\COVERT\MOVIES.MIX 0x083CE7EE
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\COVERT\MOVIES.MIX 0x082856B6
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\COVERT\MOVIES.MIX 0x07E697EE
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\COVERT\MOVIES.MIX 0x07CFB0B4
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\COVERT\MOVIES.MIX 0x07AFD71A
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\COVERT\MOVIES.MIX 0x074F1468
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\COVERT\MOVIES.MIX 0x072F1170
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\COVERT\MOVIES.MIX 0x0718E65C
@ECHO menu. Now Playing movie: INFERNO
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\COVERT\MOVIES.MIX 0x06B9E79E
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\COVERT\MOVIES.MIX 0x06B2E0DC
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\COVERT\MOVIES.MIX 0x05718C30
@ECHO menu. Now Playing movie: IONTEST
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\COVERT\MOVIES.MIX 0x0542DBF8
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\COVERT\MOVIES.MIX 0x052A2F32
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\COVERT\MOVIES.MIX 0x04F3D2AC
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\COVERT\MOVIES.MIX 0x04BB5276
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\COVERT\MOVIES.MIX 0x04742A9C
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\COVERT\MOVIES.MIX 0x04458772
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\COVERT\MOVIES.MIX 0x03F6F676
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\COVERT\MOVIES.MIX 0x03BF6338
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\COVERT\MOVIES.MIX 0x038FADB2
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\COVERT\MOVIES.MIX 0x0354E948
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\COVERT\MOVIES.MIX 0x03246258
@ECHO menu. Now Playing movie: REFINERY
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\COVERT\MOVIES.MIX 0x030B499A
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\COVERT\MOVIES.MIX 0x02A91B4C
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\COVERT\MOVIES.MIX 0x0293F472
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\COVERT\MOVIES.MIX 0x025ADB7C
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\COVERT\MOVIES.MIX 0x0245560A
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\COVERT\MOVIES.MIX 0x021C0BD0
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\COVERT\MOVIES.MIX 0x01D70C4C
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\COVERT\MOVIES.MIX 0x01A4B5AA
@ECHO menu. Now Playing movie: TRAILER
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\COVERT\MOVIES.MIX 0x00000216
CHOOSE /CNR/T:N,1
VQAPLAY CDROMS\COVERT\MOVIES.MIX 0x01617630
:VQAPLAYKEYBOARD
EDIT VQAPLAY.TXT
GOTO MEDIA
:VQAPLAYSOUND
EDIT VQAPLAY.CFG
GOTO MEDIA
:BASE
MEDIA\PICS\GDIBASE
GOTO MEDIA
:MUSIC
CLS
@ECHO Note: Open the file "C&C\MEDIA\MUSIC\Command and Conquer.m3u" using the Media
@ECHO Player for Windows to play the Command and Conquer music.
@ECHO.
@ECHO Press any key to return to the Command and Conquer Media, Movies, and Music
@ECHO menu...
PAUSE>NUL
GOTO MEDIA
REM @ECHO Do you wish to exit the Command and Conquer ¥Weeds¥ Edition launcher menu and
REM @ECHO then play the Command and Conquer music?
REM @ECHO.
REM CHOOSE /CYN
REM IF ERRORLEVEL 2 GOTO MEDIA
REM IF ERRORLEVEL 1 GOTO PLAYMUSIC
:PLAYMUSIC
REM CLS
REM @ECHO Battle control terminated. Press any key to exit and play the Command and
REM @ECHO Conquer music...
REM EVA-BCT
REM PAUSE>NUL
REM RUNDLL32 URL.DLL,FileProtocolHandler "MEDIA\MUSIC\Command and Conquer.m3u"
REM GOTO END
:NCMEDIA
CLS
C:\NC\NC
C:
CD\
CD\C&C
GOTO MEDIA
:BACKUPRESTORE
CLS
@ECHO Backup and Restore Command and Conquer Files
@ECHO [B]ackup Command and Conquer Files »
@ECHO [R]estore Command and Conquer Files »
@ECHO.
@ECHO.
@ECHO.
@ECHO [Q]uit
CHOOSE /CBR5CQ
IF ERRORLEVEL 5 GOTO QUIT
IF ERRORLEVEL 4 GOTO TOP
IF ERRORLEVEL 3 GOTO NCBACKRESTORE
IF ERRORLEVEL 2 GOTO RESTOREFILES
IF ERRORLEVEL 1 GOTO BACKUPFILES
:BACKUPFILES
CLS
@ECHO Backup Command and Conquer Files
@ECHO Backup Command and Conquer Configuration and [O]ptions
@ECHO Backup Command and Conquer [H]igh Scores
@ECHO Backup Command and Conquer [S]aved Games
@ECHO.
@ECHO Backup [A]ll Command and Conquer Options, High Scores, and Saved Games
@ECHO.
@ECHO.
@ECHO « Return to [B]ackup and Restore Command and Conquer Files Menu
@ECHO.
@ECHO [Q]uit
CHOOSE /COHSA5BCQ
IF ERRORLEVEL 8 GOTO QUIT
IF ERRORLEVEL 7 GOTO TOP
IF ERRORLEVEL 6 GOTO BACKUPRESTORE
IF ERRORLEVEL 5 GOTO NCBACKFILES
IF ERRORLEVEL 4 GOTO BACKUPALL
IF ERRORLEVEL 3 GOTO BACKUPSAVED
IF ERRORLEVEL 2 GOTO BACKUPHIGH
IF ERRORLEVEL 1 GOTO BACKUPOPTIONS
:BACKUPOPTIONS
CLS
COPY C:\C&C\*.CFG C:\C&C\CONFIG /Y
COPY C:\C&C\*.INI C:\C&C\CONFIG /Y
COPY C:\C&C\*.PIF C:\C&C\CONFIG /Y
@ECHO.
@ECHO Command and Conquer configuration and options backup done!
@ECHO.
PAUSE>NUL
GOTO BACKUPFILES
Rich ¥Weeds¥ Nagel
Reply 30 of 33, by rfnagel
Part 2 - the forum software wouldn't let me post a message so big <grin> :
:BACKUPHIGH
CLS
COPY C:\C&C\HALLFAME.DAT C:\C&C\CONFIG /Y
@ECHO.
@ECHO Command and Conquer high scores backup done!
@ECHO.
PAUSE>NUL
GOTO BACKUPFILES
:BACKUPSAVED
CLS
COPY C:\C&C\SAVEGAME.* C:\C&C\CONFIG /Y
@ECHO.
@ECHO Command and Conquer saved games backup done!
@ECHO.
PAUSE>NUL
GOTO BACKUPFILES
:BACKUPALL
CLS
@ECHO.
@ECHO Command and Conquer options, high scores, and saved games backup done!
@ECHO.
PAUSE>NUL
GOTO BACKUPFILES
:NCBACKFILES
CLS
C:\NC\NC
C:
CD\
CD\C&C
GOTO BACKUPFILES
:RESTOREFILES
CLS
@ECHO Restore Command and Conquer Files
@ECHO Restore Command and Conquer Configuration and [O]ptions
@ECHO Restore Command and Conquer [H]igh Scores
@ECHO Restore Command and Conquer [S]aved Games
@ECHO.
@ECHO Restore Command and Conquer Game [E]xecutable
@ECHO.
@ECHO Restore [A]ll Command and Conquer Options, High Scores, Saved Games, and EXE
@ECHO.
@ECHO.
@ECHO.
@ECHO [Q]uit
…Show last 350 lines
CHOOSE /COHSEA5BCQ
IF ERRORLEVEL 9 GOTO QUIT
IF ERRORLEVEL 8 GOTO TOP
IF ERRORLEVEL 7 GOTO BACKUPRESTORE
IF ERRORLEVEL 6 GOTO NCRESTOREFILES
IF ERRORLEVEL 5 GOTO RESTOREALL
IF ERRORLEVEL 4 GOTO RESTOREEXECUTABLE
IF ERRORLEVEL 3 GOTO RESTORESAVED
IF ERRORLEVEL 2 GOTO RESTOREHIGH
IF ERRORLEVEL 1 GOTO RESTOREOPTIONS
:RESTOREOPTIONS
CLS
COPY C:\C&C\CONFIG\*.CFG C:\C&C /Y
COPY C:\C&C\CONFIG\*.INI C:\C&C /Y
COPY C:\C&C\CONFIG\*.PIF C:\C&C /Y
@ECHO.
@ECHO Command and Conquer configuration and options restore done!
@ECHO.
PAUSE>NUL
GOTO RESTOREFILES
:RESTOREHIGH
CLS
COPY C:\C&C\CONFIG\HALLFAME.DAT C:\C&C /Y
@ECHO.
@ECHO Command and Conquer high scores restore done!
@ECHO.
PAUSE>NUL
GOTO RESTOREFILES
:RESTORESAVED
CLS
COPY C:\C&C\CONFIG\SAVEGAME.* C:\C&C /Y
@ECHO.
@ECHO Command and Conquer saved games restore done!
@ECHO.
PAUSE>NUL
GOTO RESTOREFILES
:RESTOREEXECUTABLE
CLS
COPY C:\C&C\CONFIG\GAME.NEW C:\C&C /Y
@ECHO.
@ECHO Command and Conquer game executable restore done!
@ECHO.
PAUSE>NUL
GOTO RESTOREFILES
:RESTOREALL
CLS
@ECHO.
@ECHO Command and Conquer options, high scores, saved games, and EXE restore done!
@ECHO.
PAUSE>NUL
GOTO RESTOREFILES
:NCRESTOREFILES
CLS
C:\NC\NC
C:
CD\
CD\C&C
GOTO RESTOREFILES
:NCBACKRESTORE
CLS
C:\NC\NC
C:
CD\
CD\C&C
GOTO BACKUPRESTORE
:SOUND
SETUP %1 %2 %3 %4 %5 %6 %7 %8 %9
GOTO TOP
:EDIT
EDIT CONQUER.INI
GOTO TOP
:ASSAULT
CLS
@ECHO Assault Trooper - BONUS GAME
@ECHO Assault Trooper Manual and [R]eadme
@ECHO.
@ECHO Assault Trooper [M]ission Builder
@ECHO Assault Trooper Mission Builder [I]nstructions and Manual
@ECHO.
@ECHO Assault [T]rooper Commando Movie
@ECHO.
@ECHO [B]ackup and Restore Assault Trooper Files »
@ECHO Assault Trooper [S]ound Configuration
@ECHO.
@ECHO.
@ECHO.
@ECHO [Q]uit
CHOOSE /CARMITBS5CQ
IF ERRORLEVEL 10 GOTO QUIT
IF ERRORLEVEL 9 GOTO TOP
IF ERRORLEVEL 8 GOTO NCASSAULT
IF ERRORLEVEL 7 GOTO ATSOUND
IF ERRORLEVEL 6 GOTO ATBACKREST
IF ERRORLEVEL 5 GOTO ATTROOPER
IF ERRORLEVEL 4 GOTO ATINSTRUCTIONS
IF ERRORLEVEL 3 GOTO ATMISSION
IF ERRORLEVEL 2 GOTO ATREADME
IF ERRORLEVEL 1 GOTO ATASSAULT
:ATASSAULT
CD ASSAULT
ASSAULT %1 %2 %3 %4 %5 %6 %7 %8 %9
CD ..
GOTO ASSAULT
:ATREADME
EDIT ASSAULT\README.DOC
GOTO ASSAULT
:ATMISSION
CD ASSAULT
ASLTEDIT %1 %2 %3 %4 %5 %6 %7 %8 %9
CD ..
GOTO ASSAULT
:ATINSTRUCTIONS
EDIT ASSAULT\MBUILDER.TXT
GOTO ASSAULT
:ATTROOPER
ASSAULT\COMMANDO
GOTO ASSAULT
:ATBACKREST
CLS
@ECHO Backup and Restore Assault Trooper Files
@ECHO [B]ackup Assault Trooper Files »
@ECHO [R]estore Assault Trooper Files »
@ECHO.
@ECHO.
@ECHO « Return to Assault [T]rooper - BONUS GAME Main Menu
@ECHO.
@ECHO [Q]uit
CHOOSE /CBR5TCQ
IF ERRORLEVEL 6 GOTO QUIT
IF ERRORLEVEL 5 GOTO TOP
IF ERRORLEVEL 4 GOTO ASSAULT
IF ERRORLEVEL 3 GOTO NCATBACKREST
IF ERRORLEVEL 2 GOTO ATRESTFILES
IF ERRORLEVEL 1 GOTO ATBACKFILES
:ATBACKFILES
CLS
@ECHO Backup Assault Trooper Files
@ECHO Backup Assault Trooper Configuration and [O]ptions
@ECHO Backup Assault Trooper High Scores and [S]aved Games
@ECHO.
@ECHO Backup [A]ll Assault Trooper Options, High Scores, and Saved Games
@ECHO.
@ECHO.
@ECHO « Return to [B]ackup and Restore Assault Trooper Files Menu
@ECHO.
@ECHO [Q]uit
CHOOSE /COSA5BTCQ
IF ERRORLEVEL 6 GOTO ASSAULT
IF ERRORLEVEL 5 GOTO ATBACKREST
IF ERRORLEVEL 4 GOTO NCATBAKFILES
IF ERRORLEVEL 3 GOTO ATBACKALL
IF ERRORLEVEL 2 GOTO ATBACKSAVED
IF ERRORLEVEL 1 GOTO ATBACKOPTIONS
:ATBACKOPTIONS
CLS
COPY C:\C&C\ASSAULT\*.CFG C:\C&C\ASSAULT\CONFIG /Y
COPY C:\C&C\ASSAULT\*.PIF C:\C&C\ASSAULT\CONFIG /Y
@ECHO.
@ECHO Assault Trooper configuration and options backup done!
@ECHO.
PAUSE>NUL
GOTO ATBACKFILES
:ATBACKSAVED
CLS
COPY C:\C&C\ASSAULT\ASSAULT.SAV C:\C&C\ASSAULT\CONFIG /Y
@ECHO.
@ECHO Assault Trooper high scores and saved games backup done!
@ECHO.
PAUSE>NUL
GOTO ATBACKFILES
:ATBACKALL
CLS
@ECHO.
@ECHO Assault Trooper options, high scores, and saved games backup done!
@ECHO.
PAUSE>NUL
GOTO ATBACKFILES
:NCATBAKFILES
CLS
C:\NC\NC
C:
CD\
CD\C&C
GOTO ATBACKFILES
:ATRESTFILES
CLS
@ECHO Restore Assault Trooper Files
@ECHO Restore Assault Trooper Configuration and [O]ptions
@ECHO Restore Assault Trooper High Scores and [S]aved Games
@ECHO.
@ECHO Restore [A]ll Assault Trooper Options, High Scores, and Saved Games
@ECHO.
@ECHO.
@ECHO.
@ECHO [Q]uit
CHOOSE /COSA5BTCQ
IF ERRORLEVEL 4 GOTO NCATRESTFILES
IF ERRORLEVEL 3 GOTO ATRESTALL
IF ERRORLEVEL 2 GOTO ATRESTSAVED
IF ERRORLEVEL 1 GOTO ATRESTOPTIONS
:ATRESTOPTIONS
CLS
COPY C:\C&C\ASSAULT\CONFIG\*.CFG C:\C&C\ASSAULT /Y
COPY C:\C&C\ASSAULT\CONFIG\*.PIF C:\C&C\ASSAULT /Y
@ECHO.
@ECHO Assault Trooper configuration and options restore done!
@ECHO.
PAUSE>NUL
GOTO ATRESTFILES
:ATRESTSAVED
CLS
COPY C:\C&C\ASSAULT\CONFIG\ASSAULT.SAV C:\C&C\ASSAULT /Y
@ECHO.
@ECHO Assault Trooper high scores and saved games restore done!
@ECHO.
PAUSE>NUL
GOTO ATRESTFILES
:ATRESTALL
CLS
@ECHO.
@ECHO Assault Trooper options, high scores, and saved games restore done!
@ECHO.
PAUSE>NUL
GOTO ATRESTFILES
:NCATRESTFILES
CLS
C:\NC\NC
C:
CD\
CD\C&C
GOTO ATRESTFILES
:NCATBACKREST
CLS
C:\NC\NC
C:
CD\
CD\C&C
GOTO ATBACKREST
:ATSOUND
CD ASSAULT
SETSOUND %1 %2 %3 %4 %5 %6 %7 %8 %9
CD ..
GOTO ASSAULT
:NCASSAULT
CLS
C:\NC\NC
C:
CD\
CD\C&C
GOTO ASSAULT
:NCTOP
CLS
C:\NC\NC
C:
CD\
CD\C&C
GOTO TOP
:DOSPROMPT
CLS
@ECHO Type EXIT to to return to the Command and Conquer Main Menu...
@ECHO.
COMMAND
GOTO TOP
:QUIT
CLS
@ECHO Battle control terminated. Press any key to exit...
EVA-BCT
PAUSE>NUL
@ECHO.
GOTO END
:END
Rich ¥Weeds¥ Nagel
Reply 31 of 33, by Svenne
There's also Dosstart, which is a bit similar to Windows 95.
Intel C2D 2.8 GHz @ 3.0 GHz | ASUS P5KPL | ASUS GTS250 1 GB | 4GB DDR2-800 | 500 GB SATA | Win 7 Pro/Ubuntu 9.10
Reply 32 of 33, by rfnagel
rfnagel wrote:
Hmmm... seems that NeoSoft has recently removed *ALL* of their older programs and utilities from their web site at http://www.neosoftware.com . DAMN... the end of an era! They must have recently (only within the past few months or so) discontinued their older product line, and utilities and programs for DOS 🙁 🙁
NeoSoft's product page used to be located at http://www.neosoftware.com/qm.html , but as above, it's long-since gone. Heh, found an Internet Archive version of the page though (from 2009) -> http://replay.web.archive.org/20090505071557/ … are.com/qm.html 😀
...and now I'm rambling on here 🤣! Just dug up my copy of QuikMenu v1.0 (circa 1990) 😀 Yep... Y2K compatible, WOOHOO!
Heh, just had a flashback... I was one of their beta-testers for QuikMenu 4 for WinDoZe <yuck!>.
Rich ¥Weeds¥ Nagel
Reply 33 of 33, by EZ
Does anyone know (where to find) a menu system called "+3 menus" (or it might have been called "3+ menus". I used it 'back in the days' and I'd love to have it back. I'd be so grateful 😀
