linux installation help
First post, by junioratknoppix
i just wonder if anybody can help me installing dosbox on my mandrake 9.0 box... the configuration script tells me that i havent got libSDL1.2 installed, but i have. i also tried it with --with-sdl-prefix but the result was that the config-script was searching for an sdl-config script which i havent got...
he also doesnt accept my version of alsa, because he says, that i havent installed the libasound.so.2, but again, i have. i also have got alsa 0.9, but he doesnt accept...
can anybody help me?
thx
Reply 1 of 3, by Harekiet
Rank DOSBox Author
DOSBox Author
you sure you installed the development versions of sdl, alsa and whatever else dosbox needs.
Reply 2 of 3, by Qbix
Rank DOSBox Author
DOSBox Author
Dosbox requires the development version of all libraries.
if you have sdl1.2.4 installed this is probably the runtime libary and not the libary against which dosbox can link. So try installing the developent versions of the libaries involved.
Water flows down the stream
