D-Fend Reloaded (DOSBox frontend)
Reply 1600 of 2280, by Alexander
@sst:
From your description its not completely clear to me, what when happens.
But anyway I guess I can't do much about this. The games list and the screenshots list are using a Windows component for displaying information in report or icon from. It's the same component the Windows Explorer uses to display the files list. I have very little influence on what exactly its doing. I can give a list and the information in which form to display the records to the component and thats it.
@Sheriff Hobbes:
Ok, added to my 1.3 wish list. With this new record the list has exactly one entry. The next month I will collect more ideas for 1.3 and then try to finish 1.3 perhaps in winter/spring next year.
Reply 1601 of 2280, by sst
Hi, ...
I use = D-Fend Reloaded, "v1.2", Portable structure.
@Alexander […]
@Alexander
I have found a name change bug, inside the screenshot section.
It's when i move the D-Fend Reloaded window, when displaying a game profile, that have 3 or more screenshot.
To reproduce that bug =
Use the windowed option
After display a game profile, that have 3 or more screenshot(s)
After move D-Fend Reloaded window "left to right" and "right to left".
After when you move D-Fend Reloaded window, you will see that the screenshot name(s) and number(s) for a profile change.
I can made a small screenshotvideo, that display that name change bug.
@sst:
See this screenshot = i have resized the window to the right.
Reply 1602 of 2280, by Alexander
D-Fend Reloaded is not executing any code related to the screenshots viewer when resizing the program window. So this is due to the Windows common control itself and therefore cannot be changed by me.
Reply 1603 of 2280, by Alexander
Two good news:
1. I was able to implement the tree view customization option without new language strings so I can add this feature in 1.2.1.
2. A release candidate of 1.2.1 is online.
Reply 1604 of 2280, by T.B.
OK, good to know.
Thank you, Alexander.
Reply 1605 of 2280, by sst
Hi, ...
I use = D-Fend Reloaded, "v1.2.1 Release Candidate", Portable structure.
Can it be made an option to
Reset all profiles to template default value(s) (not just one profile at a time). P.S. Only place that option, in the advanced configuration "Programs Settings | Services" section.
Reply 1606 of 2280, by sst
Hi, ...
Error message, ... see screenshot.
It's when inside a profile, "Tools button | reset to template | Normal DOS games... | Reset all pages but this.
Reply 1607 of 2280, by Alexander
Reset pages to template bug: Found and fixed. Additional I've found a small memory leak in the code for resetting the mounting settings which is also fixed.
The reset multiple profiles function is added to my 1.3 todo.
If no new bugs will be found by beginning of next week, I will try to release 1.2.1 beginning of next week.
Reply 1608 of 2280, by tsampikos
Well Done Alexander! Keep going! 😉 Can't wait for the new version!
Reply 1609 of 2280, by Alexander
I have just released D-Fend Reloaded 1.2.1.
@sst:
If you set the ActivateIncompleteFeatures switch in the DFend.ini you will find a new button on the service page of the setup dialog...
Reply 1610 of 2280, by sst
I use = D-Fend Reloaded, "v1.2.1", Portable structure.
It's inside "Reset multiple profiles function".
Also, ..."Reset multiple profiles function" dont display a progressbar and cant be cancelled. = is this normal ?
Reply 1611 of 2280, by Alexander
Thats bad luck. For me its working. But before making the "Reset multiple profiles" function an official 1.3 feature, of course I will do more testing. Additionally we can think about some progress dialog then.
For the moment I just hope all regular 1.2.1 features are working correctly, so I can think about 1.3 features and don't have to work on a second service release.
Reply 1612 of 2280, by sst
http://ykhwong.x-y.net/ DOSBox 0.74 SVN builds Oct. 12. 2011 Based on SVN 3752. Have new options inside the file "dosbox.conf" see attachment file included.
Below, ... some new options and some added values.
1 ) Added cputype = "486" "pentium"
2 ) Added machine = "cga_mono" "amstrad"
3 ) Added and please change scaler = see below
none
normal2x
normal3x
advmame2x
advmame3x
advinterp2x
advinterp3x
hq2x
hq3x
2xsai
super2xsai
supereagle
tv2x
tv3x
rgb2x
rgb3x
scan2x
scan3x
hardware2x
hardware3x
No Scaling (none)
Nearest neighbor upscaling with factor 2 (normal2x)
Nearest neighbor upscaling with factor 3 (normal3x)
Advanced upscaling with factor 2 (advmame2x)
Advanced upscaling with factor 3 (advmame3x)
high quality with factor 2 (hq2x)
high quality with factor 3 (hq3x)
2xsai (2xsai)
super2xsai (super2xsai)
supereagle (supereagle)
Advanced interpoling with factor 2 (advinterp2x)
Advanced interpoling with factor 3 (advinterp3x)
Advanced upscaling with sharpening with factor 2 (tv2x)
Advanced upscaling with sharpening with factor 3 (tv3x)
Simulates the phopsphors on a dot trio CRT with factor 2 (rgb2x)
Simulates the phopsphors on a dot trio CRT with factor 3 (rgb3x)
Nearest neighbor with black lines with factor 2 (scan2x)
Nearest neighbor with black lines with factor 3 (scan3x)
4 ) New linewise = "true" "false"
5 ) New char9 = "true" "false"
6 ) New multiscan = "true" "false"
7 ) New vsyncmode = "off" "on" "force" "host"
8 ) New vsyncrate = "Vsync rate used if vsync is enabled. Ignored if vsyncmode is set to host (win32)."
9 ) Added core = "full"
10 ) New swapstereo = "true" "false"
11 ) New files = "127" , ...
Reply 1613 of 2280, by Alexander
I will try to support as many as possible of these settings in DFR 1.3.
Reply 1614 of 2280, by sst
WebSite =
Sunday, 10/23/2010 D-Fend Reloaded 1.2.1 has been released.
D-Fend Reloaded 1.2.1 is a bug fix and service release. D-Fend Reloaded 1.2.1 corrects all bugs found since the release of version 1.2.0. A complete list of all changes can be found in the changelog file. All available versions can be downloaded from the download page.
1)
Error = Sunday, 10/23/2010
Must be = Sunday, 10/23/2011
2)
No new bug to report, ...
3)
No new post since ~10 days
Reply 1615 of 2280, by Alexander
1. Fixed.
3. Looks like everything is fine this time. And because I don't have any real new features on my todo I'm not working on DFR at the moment. But we can think of features for a 1.3 release beginning next year.
Reply 1616 of 2280, by Ambit Energy
I went through all the hassle of register blah blah...verify blah blah...Just to say WOW...I am greatly impressed and thankful for your making D-fend available. I got AutoCadR12 a powerful productivity program to work with it. This not only returned customization power long removed from current AutoCad, but it also allowed me to utilize a oldschool plotter from a company that is no longer in business!!! And most of all, I was able to access these still useful and powerful tools without wiping out a entire computer system using XP (in order to dedicate it to old school power).
Finally, WOW, my computers never run faster then those good old DOS days. Thanks.
John Galt
St. Louis, Missouri
Reply 1617 of 2280, by sst
@Alexander
Please = "moderate and/or look" at that forum section on PortableApps.
Someone made a section for D-Fend Reloaded, on PortableApps November 3, 2011. It dont include a download link­.
See this url link.
http://portableapps.com/node/29677
Reply 1618 of 2280, by Az
I thought i'd try playing an old game again, but when I try open the D-Fend Reloaded shortcut on the desktop I keep getting this error.
It worked sometime ago but not now, I have tried installing the newest version but keep getting the game, any ideas?
Reply 1619 of 2280, by Alexander
Hi Az,
the error message says "Out of system resources". That's strange. The given address does not point to a line of code so I don't know what exactly is going wrong. But because D-Fend Reloaded usually is not using more than a few MB of RAM, I would guess of one of the following things as the reason for the error message:
1. You try to load a damaged image (as screenshot for example) in DFR.
2. Something is wrong on your system.
3. There is a bug in the Delphi runtime library.
