First post, by PunkMaister
- Newbie
I have a Toshiba 4GB RAM, 500GB Hard Drive Pentium Dual Core with integrated Intel HD Graphics and Connexant Smart Audio Laptop. I have it hooled to my old tower Dell SVGA monitor and to my HD TV set as well both acting as primary and secondary displays respectively with the main Laptop's screen turned off because the Intel/Nvidia chipset does not support using more than 2 displays at one time.
Anyhow the problem is that whenever i try to switch to full screen in DOSBox under the current configuration both screens go blank and nothing appears on either one.
Any idea as to what could be causing DOSBox to operate in this manner and what if anything can be done about it?
