Alexander wrote:trying to select a MIDI interface
Do you mean clicking the "Select MIDI device from device manager" button on the MIDI page of the profile editor?
Correct. 😀
Alexander wrote:As a first workaround you can get a list of MIDI devices available inside DOSBox from the DOSBox command line by typing "mixer /LISTMIDI". (That's also what DFR does when clicking the select MIDI device button.)
Thanks I didn't know this! When I do this, I get the Midisport listed, which is correct!
Alexander wrote:If you just enter the name of the device you want to use from this list in the "Additional settings" field on the MIDI page of the profile editor it will be exactly the same as if you would have clicked the select button.
This is where it, unfortunately, crashes. Writing the name of the device on the "Additional settings" field (or, in fact, any value at all, like ABC123) and then trying to start the game, D-Fend crashes.
Also, if I write the name of the device and then, for example, click on Tools --> View DOSBox Conf file, D-Fend crashes as well.
Is there anyway I can:
a) See a log to find out how or why it crashed?
b) Delete anything from D-Fend Reloaded\Settings folder to "reconfigure" the software?
Thanks in advance, Alexander!
