SOS!!!
First post, by guest
I am new to this, and am wondering how you can help me.
I downloaded DOSbox, because I am having trouble running my SWOS under Windows XP.
Anyway, after installing it and running it, I followed on-screen instructions to MOUNT c:\drive.
This did not work - I got an error message coming up saying "C Drive Does Not Exist"
I tried the other old trick of changing directories - "C:" - but to no avail as the program refused to acknowledge the very drive it is installed on.
Can someone help me desperately?
PS: Curiously, Does DOSbox support/plan to support USB devices with most joystick techonology upgraded nowadays?
Thanks.
Lee
Reply 1 of 2, by rgriff
Did you remember to put the forward slash after the colon? If you don't, you get an error:
mount c c:
Directory c: doesn't exist.
mount c c:\
Drive C mounted as local directory c:\
What is your exact input and error message?
Also, my USB joystick does work with games run through DOSBox (Humans, e.g.).
Reply 2 of 2, by Cthulhus
use a Frontend ... It's mad DosBox very easy to use under Windows XP !
Download it here :
http://members.home.nl/mabus/dfend.htm
