Reply 1060 of 1972, by R33D3M33R
- Newbie
Hello rcblanke, I just discovered this great cross platform Dosbox frontend recently. First of all, I would like to thank you for your work, the application is great.
I have attached Slovenian translation for the application. The translation is 100% and converted (please check if it's really ok). I was able to verify most of the messages in GUI.
I have some suggestions for the application. Maybe they were already made, but since the thread is so gigantic, I just didn't have the time to check:
1. Include translations in the release, but with removed .utf8 files (if the program doesn't need them). 200 kB is nothing by todays standards, but the users will sure be grateful for a GUI in their language without the need to install anything. The pack with both types of files can still be available for D/L from the website.
2. There seems to be no way to select a custom thumbnail image for the tiles unless you copy existing screenshots in the game screenshot folder.
3. Different thumbnails sizes available are great, but I surely wish you could make a slider which could dynamically adjust size of thumbnails. The slider values don't need to be continuous, just go from the smallest size available now, to the size which fills two rows.
Thanks again!
