First post, by Danfun64
I am running Windows 3.11 for Workgroups on Dosbox and I am curious if there is a way to turn on general midi. I have the sb16 drivers installed, but do I need any other drivers for midi?
edit: Also related, how do I increase the volume of the fm synth in windows 3.x using the sb16 drivers?
I tried fiddling around with MIXER settings, but windows 3x automatically resets CDAUDIO, SB, and FM to 58:58. Not so bad for sound effects, but too low for music.
Reply 2 of 4, by Danfun64
I figured out my MIDI problem, but what about the volume control in Windows 3.x?
Reply 3 of 4, by truth_deleted
Provide details on your test of volume control in Windows 3.1x.
Reply 4 of 4, by ripsaw8080
Rank DOSBox Author
DOSBox Author
The SB16 drivers for Windows 3.x should install a Win16 mixer application (e.g. C:\SB16\WINAPPL\CTMIXER.EXE) to change volume levels. However, you can use the sbmixer=false setting if you don't want DOSBox's mixer volume levels to be overriden by the SB mixer volume levels.
