First post, by JekhoOne
Hi All,
i am mtrying to use DosBox in order to "let survive" an old diagnostic application on my company network.
All work fine for two COM port (RS232) configured as directserial and properly working with other DTE or instrumentation devices.
The only problem is a remote communication of data to be perform with an external 56k modem.
Configuring the serial port (COM3) with the "old" configuration (Baud Rate=9600, Parity=None, Data Bits=8, Stop Bits=1, flow control= None) it seems that the application didn't retrieve the external modem without start the call with ATDT command.
If I set the COM3 as emulated modem the application retrieve the modem devices (emulated) start the call with the ATDT command and, of course, is not able to complete the action.
Modem is properly driven with AT dos command (echo AT > com3), so serial communication and modem device are ok.
My question is : which kind of operation or setup is doing the emulated modem SW in order to be detected by the application ? I would like to receive this last information in order to initialize the external "real" modem in order to be detected by the application.
Thanks in advance for your support.
Regards
J
