First post, by Guest
I am a linux user and I have juste discovered then installed DOSBox which looks very promissing ; I am still using freeDOS until I have a clear understanding of the way to use DOSBox ; so far this is where I stand :
a) installing my floppy drive by executing the command :
mount a /mnt/floppy
but to see something with DIR I have to apparently to read my floppy through my Navigator first ; I think the reason is that I am using supermount on my floppy disk which mount and unmounts my floppy drive on demand and as DOSBox is an emulator through Linus it has to go through Linux rules ;
b) installing my DVD drive by executing the command :
mount -t cdrom c /mnt/cdrom
though the doc says something different ; though cd drives are not using supermount on my system but hotplug the same rules as above apparently apply ; if I execute :
mount -cd
CDROMS found: 1
0. /dev/cdrom
therefore locating only one cd drive (as inferred by the documentation) I could also (!) mount my burner installed on "/mnt/cdrom2" by executing :
mount -t cdrom d /mnt/cdrom2
with the same remark as for cdrom.
c) question on "Z:\" volume
I was expecting the "Z:\" volume to be physically imaged on my system somewhere in "/usr/local" where DOSBox is installed but sofar it is nowhere to be found as purely software created ! ; in freeDOS the initial volume as shown at promp does physically exist and allows for modifications of files contained inside like AUTOEXEC.BAT ! ; I whish I could know better here !
d) keyboard mapping
With my AZERTY keyboard still globally seen as AZERTY mapping I am experimenting some problem as some very few keys do not yield any action ! ; I have seen a few messages asking for clarification with "impossible !", "useless !" ; then "possible to use freeDOS keyboard mapping with a file proposed !" ; if somebody here can explain clearly how I can install freeDOS keyboard mapping on my Linux systemto achieve same effect as with freeDOS I would appreciate !
e) sound play
Any DOS sound command to play sound ?
That will be all for today.
Regards
