First post, by MothingMan
Hi, I am trying to get a DOS programme to run under Linux 64 bit with DosBox ( Other programmes work Ok ).
This programme opens a very basic screen and nothing more. I am sure this is because it cannot find required directories, under DOS these directories are listed in the PATH. I can find no reference to Path in the DosBox config file.
So it possible to define the required Path somewhere ?
Dave P..
