Screen Wrap
First post, by Netskimmer
Hi all, I posted this problem about six months ago and got no resolution so I though I’d try again. When I try to run any games in DOSBox a small strip of the left side of the screen wraps around to the right side. I’ve tried messing with my monitor settings, screen resolution and even switched monitors and updated my vid drivers, but nothing fixes it. Does anyone know what is causing this and how I can fix it?
Here are my relevant system specs:
Time of this report: 12/25/2004, 14:15:12
Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 2 (2600.xpsp_sp2_rtm.040803-2158)
Language: English (Regional Setting: English)
BIOS: BIOS Date: 08/20/03 12:57:55 Ver: 08.00.09
Processor: Intel(R) Pentium(R) 4 CPU 2.80GHz (2 CPUs)
Memory: 1022MB RAM
Page File: 403MB used, 1524MB available
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.2600.2180 32bit Unicode
Card name: RADEON 9600 SERIES
Manufacturer: ATI Technologies Inc.
Chip type: RADEON 9600 XT AGP (0x4152)
DAC type: Internal DAC(400MHz)
Device Key: Enum\PCI\VEN_1002&DEV_4152&SUBSYS_00021002&REV_00
Display Memory: 128.0 MB
Current Mode: 1024 x 768 (32 bit) (85Hz)
Monitor: HP D2845 Ergo 1600 21-inch Display
Monitor Max Res: 1600,1200
Driver Name: ati2dvag.dll
Driver Version: 6.14.0010.6497 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 11/30/2004 22:12:50, 221184 bytes
WHQL Logo'd: Yes
WHQL Date Stamp: n/a
VDD: n/a
Mini VDD: ati2mtag.sys
Mini VDD Date: 11/30/2004 22:12:28, 873984 bytes
Reply 1 of 20, by MiniMax
Rank Moderator
Moderator
Do the same thing happen if you run one of the little wonders from http://www.256b.com/ in full screen mode from the XP CMD.EXE ??
Try this one: http://www.256b.com/download/375
_________________
Reply 3 of 20, by DosFreak
Haven't used those demos but it's possible they use a color mode that's not compatible with DosBox, since DosBox only supports 8bit and they probably want 15,16, or 32bit.
Have you tried aspect=true in dosbox.conf or any of the other screen options?
Make your games work offline
Reply 5 of 20, by MiniMax
Rank Moderator
Moderator
DosFreak - I specifically said "in full screen mode from the XP CMD.EXE", so DOSBox should not be a factor.
On my system, I get a nice rotating, purple/orange torroid on a greenish background with both XP/CMD.EXE and DOSBox.
If Netskimmer/Guest gets garbled graphics, then something is(?) wrong with his graphics card/driver - which explains the problem with graphics wraparound in games.
    5.54 KiB
    The Torroid, captured in DOSBox.
_________________
Reply 7 of 20, by DosFreak
Well you should definetly try the latest ATI drivers.
Latest are CAT v5.1 which according to the info you posted you don't have installed.
Doubt they'll fix your prob tho.
Reply 13 of 20, by Netskimmer
It happens starting in full screen and window. I know it doesn't look too bad from the screen shot but it gets annoying, especially with an animation playing.
    40.09 KiB
Reply 16 of 20, by mirekluza
Rank DOSBox Moderator
DOSBox Moderator
Do not expect support for 0.61. It is taken as normal, that anybody wanting any help here uses the latest version!
If you have problems with some games in the newest version, then report them! Otherwise they cannot be repaired.
Mirek
