First post, by Trekkie
HI, I got Dosbox a few days ago in order to get my old Wing Commander games running on XP, but whenever I try to mount my hard drive, I get a "this drive does not exist" message. With the CD drive it's the same. A friend said it might be a problem with laptop components, do you think that's true? How can I fix this problem? I hope you can help me, and thanks in advance...
Reply 1 of 18, by Freddo
Exactly what do you type when you try to mount your hard drive?
Reply 2 of 18, by Trekkie
what it says in the readme...mount c c:\programs... is there a problem with that? I tried without a subdirectory, too, but the dosbox doesn't accept that...
Reply 3 of 18, by MiniMax
Rank Moderator
Moderator
Try something like this:
  1. Outside of DOSBox, create a directory that will hold all your DOSBox games,
    e.g. "C:\OldGames".
  2. Beneath "C:\OldGames", create a directory for Wing Commander,
    e.g. "C:\OldGames\WingCmd".
  3. Insert CD in drive.
  4. Start DOSBox.
  5. In DOSBox, mount up drive C and D.
    Z:>mount C "C:\OldGames\WingCmd"
    Z:>mount D "D:\" -t cdrom -ioctl
  6. Install the game from D: to C:
    Z:>D:
    D:>WC -I (or install, setup, or whatever....)
  7. Configure sound, ....
  8. Start game.
_________________
Reply 6 of 18, by MiniMax
Rank Moderator
Moderator
I am now officially confused 😕 😕 😕 😕
_________________
Reply 7 of 18, by Qbix
Rank DOSBox Author
DOSBox Author
what did you type in dosbox.
exactly ?
Water flows down the stream
Reply 9 of 18, by eL_PuSHeR
Why are you using double quotes from DOSBox prompt?
Besides directory names seems to be 8.3 compliant...
Type this under DOSBox prompt...
Z:>mount C C:\OldGames\WingCmd
Z:>mount D D:\ -t cdrom -ioctl
Z:>c:
C:>cd oldgames
C:\OLDGAMES>cd wingcmd
C:\OLDGAMES\WINGCMD>wing.exe (or whatever you use to start the game)
Reply 10 of 18, by MiniMax
Rank Moderator
Moderator
Because it is a good habit that may avoid problems in the future.
_________________
Reply 11 of 18, by Guest
@Pusher: That's exactly what I did and it didn't help...
@DosFreak: I'll have another try with that. Which file or folder should I use, the Wing Commander .exe file?
Reply 12 of 18, by eL_PuSHeR
I was guessing using double quotes was for Long Filename support which, as far as I know, isn't supported yet under DOSBox. Am I missing something?, I am confused.
Reply 14 of 18, by MiniMax
Rank Moderator
Moderator
You are confused. Or maybe I am? 😀
As far as I can tell, the mount accepts quotes, long file name, illegal (according to DOS) file names, etc, etc, and passes it to the host OS for parsing/processing. mount (and DOSBox) does not care. If the host OS accepts it and return some kind of file/directory handle to use as the virtual drive, DOSBox is happy 😀
_________________
Reply 15 of 18, by eL_PuSHeR
Thank you for the clarification 😀
Reply 16 of 18, by Trekkie
I've got another problem now, whenever I try to install the game I get the message "ems driver is not VCPI compliant". As I have absolutely no idea what that signifies, I can't even tell if this should be posted under "application specific problems", I simply don't know if the problem is with the game or with DosBox itself. I hope you'll help me anyway...
Reply 17 of 18, by MiniMax
Rank Moderator
Moderator
@Trekkie - find your dosbox.conf file (C:\Programs\DOSBox\dosbox.conf ??) and the line that says ems=true. Set it to false. Start DOSBox.
_________________
