First post, by JeZxLee
I am running Linux Mint 18 MATE 64Bit(based on Ubuntu 16.04 64Bit) fully updated.
I am running current DOSBox with 7th Generation Intel graphics.
When I run any DOS game in DOSBox it runs for a couple of minutes and then crashes to desktop?
When I run DOSBox in terminal I get the following error on the above crash:
jezxlee@NewThinClient ~ $ dosboxDOSBox version 0.74Copyright 2002-2010 DOSBox Team, published under GNU GPL.---CONFIG:Loading primary settings from config file /home/jezxlee/.dosbox/dosbox-0.74.confMIXER:Got different values from SDL: freq 44100, blocksize 512ALSA:Can't subscribe to MIDI port (65:0) nor (17:0)MIDI:Opened device:noneDOSBox switched to max cycles, because of the setting: cycles=auto. If the game runs too fast try a fixed cycles amount in DOSBox's options.Exit to error: DRC64:Unhandled memory reference
The only changes to DOSBox configuration file were the following:
windowresolution=1024x1024output=opengl
Any help would be appreciated, thanks!
Jesse
