BUFFERS and FILES
First post, by MCardy
my application I like to run in DOSBOX needs some settings in the CONFIG.SYS file in an old DOS-enviroment.
I have to set:
BUFFERS=40
FILES=101
How can I do that in DOSBOX or isn't that possible?
Rgrds,
MCardy
Reply 1 of 2, by iampiti
This has been discussed billions of times. Always search before posting.
Anyway...: You can't change the files value in dosbox. Dosbox sets it internally to a value that should be enough for most applications.
Try running it and if it doesn't work try creating a "fake" config.sys in the folder mounted as C under dosbox.
Iampiti
Reply 2 of 2, by Qbix
Rank DOSBox Author
DOSBox Author
yes iampati is right
For the record
we have
buffers=50
Files=126
Water flows down the stream
