First post, by donmack
I need to run a DOS program in DosBox that needs to find a drive Z:\ to check for up-to-date files before it will run. Usually we run a “subst” to make a drive Z:\ from drive C:\
Is there a way I can make the DosBox virtual drive something other that Z:\ so that I can mount C:\ as Z:\ , or is there a way I can mount/subst C:\ as Z:\ even though Z:\ is already the default drive of DosBox.
