First post, by Kuro_Neko
I just installed Dosbox 0.74 on my Windows 10 home 64 bit and when I run it the first dosbox window appears fine, then the actual command prompt window attempts to open, then all my monitors stop receiving and my keyboard freezes. Any audio playing in the background continues to do so, so the whole system doesn't seem frozen, but I can't click out of it, I can't alt+f4 out of it, or alt+tab, or even ctrl+alt+del. Nothing I've tried gets the monitors back or the keyboard working. I just have to hit the reset button. All dosbox settings are default. Any suggestions would be appreciated.
Reply 1 of 18, by Jorpho
That is very unusual and I would expect other applications might start causing problems.
But for a start, using output=opengl or output=openglnb in your dosbox.conf might be worth trying.
Reply 2 of 18, by Kuro_Neko
Tried both. Problem persists. Also, I've noticed no other system instability.
Reply 3 of 18, by Jorpho
But have you been running other games? Does ScummVM work?
Reply 4 of 18, by Kuro_Neko
Modern games work fine. I'd never heard of ScummVM, but I just downloaded it and it works fine in Windowed mode or fullscreen mode. Keyboard and mouse input work fine. I can play a game fine and exit normally.
Reply 5 of 18, by Jorpho
No one has ever described a problem quite like this here before.
All I can suggest is updating your video card drivers.
Reply 6 of 18, by awgamer
There is no reason to use windows 10, all it has it dx12, of which there are really just three dx12 only games.
Reply 7 of 18, by Kuro_Neko
Drivers are up-to-date.
Be that as it may, that's what I have right now and downgrading would be an awful amount of trouble just for this.
Are there any other trouble-shooting steps anyone could suggest?
Reply 8 of 18, by Jorpho
This isn't on a tablet, is it? Often people have problems running DOSBox on a tablet, though even then the symptoms are entirely different from what you describe. In that case the quick and easy solution is to plug in a mouse, odd as it sounds. Does that make any difference?
Reply 9 of 18, by Kuro_Neko
Nope Desktop PC.
SYSTEM LIST
Motherboard
ASUS Z170-A
CPU
Intel Boxed Core I7-6700K 4.00 GHz 8M Processor Cache 4 LGA 1151
Memory
2x Corsair Vengeance LPX 8GB DDR4 DRAM 2400MHz (PC4-19200) C14
Hard Drives
OCZ Vertex 460 SSD 480GB, SATA III
Western Digital WD5000AAKS-FR 500GB 7200 RPM 16MB Cache SATA 3.0Gb/s
Western Digital 1TB, 5400RPM, 32MB Cache, SATA II
Optical Storage
LG WH14NS40 14X SATA Blu-Ray Internal Rewriter
Other Storage
Startech 5.25" USB3.0 multi-card reader
Startech 5.25in Bay Mounted 2.5in and 3.5in SATA Hard Drive Docking Station
Cooler
Corsair Hydro Series H100i GTX High Performance Liquid CPU Cooler
Video Card
ASUS STRIX-GTX980TI-DC3-6GD5-GAMING
Chassis
Corsair 500R
Power Supply
Corsair RM850i Gold PS, 850W
WebCam
Logitech c920 webcam
Mouse
SteelSeries Sensei Raw 7 button wheel Mouse, USB
Keyboard
Azio MGK1-K Backlit Mechanical Gaming Keyboard, USB
Monitors
19" Philips 109B6 CRT
15" LG Flatron 563LE LCD
23" HP w2408h LCD
19" LG 20M37 LED LCD
Scanner
Epson Perfection 1660
Printer
Hewlett Packard deskjet 3000, USB (color laserjet)
Speakers
2 KOSS HDM/265 speakers + 1 KOSS SW/100 Subwoofer
Panasonic RP-HTX7 Stereo Headphones
OS Media
Windows 10 Home x64
Reply 10 of 18, by Jorpho
I assume you're using the official DOSBox 0.74. Do any of the other commonly-available builds react differently?
You can try setting the environment variable SDL_VIDEODRIVER=dummy before starting DOSBox. (I assume you know how to do that.) That will cause DOSBox to not draw its main window at all. (That also means that you will need to kill DOSBox in Task Manager to shut it down, or start it with the "-c exit" switch.)
Reply 11 of 18, by Kuro_Neko
Yes I'm using the official version. I'm not aware of any other builds. Link?
I'll give your other suggestion a try right now.
edit:
Ok, that suggestion stopped it from freezing my system, but without the main window I'm not sure how I'm supposed to actually use dosbox to play any games.
Reply 12 of 18, by lightmaster
DO you have dos games?
Reply 13 of 18, by Kuro_Neko
Yes of course. Dosbox wouldn't be much use to me otherwise.
Reply 14 of 18, by lightmaster
Not illegal ones right?
Reply 15 of 18, by Jorpho
Kuro_Neko wrote:
edit:
Well, at least that rules out unusually exotic problems.
Let's start with this: the GOG version of Teenagent is packaged with DOSBox, and it's a free download. Does that work?
https://www.gog.com/game/teenagent
Reply 16 of 18, by Kuro_Neko
No. Either abandon-ware, share-ware, or games I actually bought back in the day. I fail to see how that question has anything to do with my issue though.
Jorpho wrote:
Well, at least that rules out unusually exotic problems. […]
Kuro_Neko wrote:
edit:
Problem persists. As soon as the dos emulation window appears the monitors go dark (with the power lights flashing as they do when they have no signal) and the keyboard freezes (lights stay lit but I can't toggle numlock or use the win button or ctrl+alt+del, etc).
Reply 17 of 18, by lightmaster
Looks like a driver issue, try reinstalling it with DDU.
Reply 18 of 18, by gdjacobs
Kuro_Neko wrote:
No. Either abandon-ware, share-ware, or games I actually bought back in the day. I fail to see how that question has anything […]
Kuro_Neko wrote:
edit:
Aside from legal factors which are also at play, avoiding "abandonware" is also policy here to simplify troubleshooting. With genuine titles (either shareware, freeware, or purchased software), we have a baseline as far as configuration, directory contents, and file versions. Unofficial software (such as "abandonware") isn't necessarily pristine.
