First post, by Giorgos
Hi! 😎
I have problems at Windows 10 x64 with sound (with all games).
Increasing block size and decreasing frame rate helps, but doesn't solve the problem.
Does anyone else, have problems with sound?
G.
For the glorious men, every land is a grave.
Thucydides: Pericles' "Funeral Oration".
Reply 1 of 5, by olddos25
What problems do you have exactly? I can't help you if you give little information.
Just another user that likes old OSes and videogames, nothing interesting to see here...
Other places to find me:
DraStic: http://drastic-ds.com (as dsattorney)
Reply 2 of 5, by Giorgos
Is of very low quallity, with lagging and breaks and trembling and very inferior. 😵
I didn't change anything from the last time I used it (at Win 7), so it was an unpleasant surprise for me.
Seems to me, that either Win 10 is a tottal crap, or Dosbox needs an update (specially for 64-bit systems).
Anyway! I installed DOSBox at my Debian system and it works flawlessly, so I'll play games there.
Thanks!!! 😀
PS. I'm still qurious! Does anyone else faced similar problems at 10;
Reply 3 of 5, by olddos25
Try going to the mixer section and changing the rate parameter to 44100.
Reply 4 of 5, by Giorgos
Indeed, increasing block size and decreasing frame rate helps, but doesn't solve the problem and the bad thing is that at Win, you don't have any alternative interface.
Reply 5 of 5, by olddos25
Hmm. That is strange. I didn't had any problems with the sound on Windows 10.
