First post, by msoulier
I fired up dosbox on retropie with a fairly standard dell keyboard attached, and the keys are so wrong that I can't get out of dosbox again and have to power cycle.
Is there a recommended way to get dosbox keymappings to be correct? I tried options to force a US keyboard but I didn't notice a difference.
Thanks,
Mike
Reply 1 of 4, by Jorpho
Maybe you should ask the Retropie people?
Reply 2 of 4, by msoulier
Possibly, but I think they're just packaging dosbox, and the keyboard mappings on the retropie work fine in general.
Reply 3 of 4, by Super_Relay
i believe you are correct they are just packaging dosbox.
the trick on a pi is to edit the .conf file and change usescancodes to false. it should fix the keyboard in dosbox if you are not running it from X
from memory it should be in /home/pi/.dosbox
Reply 4 of 4, by msoulier
Thanks that did work.
