shortcut to mount, launch game?
General information and assistance with DOSBox.
Postby recdf » 2017-7-10 @ 19:32
Hello.
I have successfully installed win 3.1 in DOSBox SVN-Daum and a game I want to play too.
Is there a way I can skip manually mounting c:\dos, cd to WINDOWS, WIN, mounting the ISO of the game etc?
Can I write a shell script to do this for me? I tried using save states but it didn't work.
recdf
Re: shortcut to mount, launch game?
Postby lightmaster » 2017-7-10 @ 19:36
Read the announcements please..
User avatar
lightmaster
Postby collector » 2017-7-11 @ 00:24
Also note that Daum is broken, nor is it an official build.
User avatar
collector
Postby olddos25 » 2017-7-13 @ 19:02
Vanilla DOSBox can also run Windows 3.1 with no problems.
You can't be the best,but you also can't be the worst
Other places to find me:
DraStic: http://drastic-ds.com (as dsattorney)
EPForums: http://www.epforums.org (as emulationfan)
User avatar
olddos25
Postby Jorpho » 2017-7-14 @ 00:33
recdf wrote:Is there a way I can skip manually mounting c:\dos, cd to WINDOWS, WIN, mounting the ISO of the game etc?
Use the [autoexec] section of DOSBox.conf. This is discussed both in the readme and in the 60 Seconds Guide.
viewtopic.php?f=39&t=8933
Don't use savestates unless you absolutely have to.
User avatar
Jorpho
Postby recdf » 2017-7-15 @ 14:09
Jorpho wrote:
Why's that? Is it broken? I can't get it to work.
Also the game I'm playing (Daedalus Encounter) requires changing CD halfway through. Is there a way to do this? If I mount all three CDs at startup, the game doesn't launch.
The only work around I can think of is binds.
Edit: I tried doing "Mounting multiple images (ISO or CUE/BIN)
Z:\>IMGMOUNT E C:\Images\MyImage1.iso C:\Images\MyImage2.iso -t iso"
but I get an error about a movie file cant be opened
recdf
Postby Jorpho » 2017-7-17 @ 04:33
recdf wrote:Why's that? Is it broken? I can't get it to work.
As has been mentioned, the latest version of the Daum build is indeed rather broken. But savestates in DOSBox are generally experimental – there are many, many more things to keep track of than in a typical game console emulator.
That is the correct syntax, yes.
However, you will notice that your error message refers to a file on drive D. Why are you using "IMGMOUNT E" instead of "IMGMOUNT D" ?
User avatar
Jorpho
Return to DOSBox General
Who is online
