First post, by Guest
One game in particular, actually. Inherit the Earth: Quest for the Orb. I installed it off the CD-ROM when I got it, and it worked pretty well. Unfortunately, that was about eight years ago, and sometime in between I managed to lose the CD-ROM. I think I can still use the diskettes, though, so that's not a problem.
This is the problem.
When I type "install", it brings up a list of the drives I have mounted, like so:
http://www.imagehosting.us/index.php?action=s … ow&ident=472830
I've gone through the guides, at least all the ones I could find, and searched the forums a couple of times ('swhere I found most of the guides, heh.) I'm pretty sure this is not supposed to happen. Can anyone tell me what's going on?
Reply 1 of 5, by wd
Rank DOSBox Author
DOSBox Author
Look at the size of INSTALL.EXE
Is it zero bytes in your host OS, too?
Reply 2 of 5, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
If you're in luck, this works:
Rename FILE0000.CHK to install.exe and try again.
Reply 3 of 5, by Guest
That's /strange/. How on earth can a file be zero bytes?
But yes, it's zero bytes in Windows XP too.
Reply 4 of 5, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
The FAT or file entry got corrupted and a repair utility wrote the lost clusters to file0000.chk back in 1998. If you are in luck, the file0000.chk contains the program that was in install.exe before.
Reply 5 of 5, by Guest
...Apparently I am not in luck. SNAP.
(it keeps telling me 'program failed to run, abort/retry/fail', and I may not know much but I know what that means, especially the sixth time it pops up.)
Ah well. Thanks anyway!
