First post, by MontyOnTheRun
I was wondering is there is any way to detect in runtime if we're running inside DOSBox? Maybe exploit some quirk on the emulation that would allow probing the "system"? It would be useful for debugging stuff that's only available in real hardware ie: I'm working on OPL2LPT support for my games - having that output redirected to a regular Adlib (when applicable) would be useful.
Thanks!
Context: I'm using GCC 7.1 with DJGPP.
Reply 1 of 6, by Qbix
Rank DOSBox Author
DOSBox Author
I am sure this question has been answered before. DOSBox has written DOSBox at several location in the emulation memory (like the bios name for example) (which you can find in the ROM at the right location)
Water flows down the stream
Reply 4 of 6, by Srandista
Could you please re-upload it, if you have it (the original upload is down)?
Reply 6 of 6, by IIGS_User
This is db-info.bat made by forum member Minimax, but be aware that there will be some incompatibilities with the latest versions of DOSBox.
    db-info.zip
    1.93 KiB
    92 downloads
    db-info.bat by forum member Minimax
Klimawandel.
