Win XP DosBox Printing
First post, by DiFra
Hello,
i need to run a TP7-Program with your DoxBox. With these Software i have to print too. It does'nt print. Printer is Canon BJ C 85 (LPT1).
May anybody help me?
Greetings from germany
Dieter
Email: Frankenberger@email.de
Reply 1 of 5, by Qbix
Rank DOSBox Author
DOSBox Author
dosbox it's gaim is games. hence no printing capabilities are present
Water flows down the stream
Reply 2 of 5, by DiFra
Hello,
and thank you for so quickly answer.
Is there any chance to get a fix for the problem?
Anybody knows a Softwareproduct to fix the problem?
PS:
At moment I work with SLOWDOWN.EXE to slowdown the DOS-Windows speed. Also I worked with TPPATCH and patched the exe-files. Most works. But some of them doesn't.
Greetings
Dieter
Email: frankenberger@email.de
http://www.sonnigelehne.de
Reply 3 of 5, by Qbix
Rank DOSBox Author
DOSBox Author
uhm well there exists a patch for dosbox which adds printing support.
However it doesn't work against the current source.
You need an older version of the dosbox source, apply the patch and compile dosbox.
It should do marvels.
Reply 4 of 5, by ih8registrations
Well, there is way: Virtual printer
Print as an image or run through an OCR program to print normally.
Reply 5 of 5, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
As far as I remember there is a binary provided in the printer port thread.
